Need Help with Headlight Switch
Old Feb 25, 2001 | 12:27 PM
abmtnbkr's Avatar
My Headlight switch has broken loose. When I go to turn the headlights on its not a problem but when I try to turn them off, the whole assembly moves towards the back. I gotta struggle with turning the lights off. I tried to take the **** off but can't. Anyone out there know if I need a special tool or ifI'm just cheating in the weight room? Also, what do I have to look forward to when trying to repair this?
Old Feb 25, 2001 | 06:02 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The headlight switch is mounted to the plastic panel, held in by a couple of torx screws. I assume the 89's had the forever used pull out ****. take the torx screws out & pull the switch out,, there is a little button on the top of the switch that hold the **** in place, press it down while pulling the know out & it should pop free. Unplg the switch & replace. As the great Haynes manual says,, installation is reverse of removal.
My Firebird It Lives Again!!
Your Car Here?
Part Diagrams
Old Mar 2, 2001 | 10:27 PM
abmtnbkr's Avatar
Deadbird,If you didn't get my Email..I just wanted to thank you for helping out on the headlight switch. I never saw that button until you told me about it. You DA MAN...
tglennon11
Sep 23, 2015 05:30 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
Randomtask2
Sep 10, 2015 08:37 AM
sylentnite
Sep 9, 2015 02:55 PM
luvofjah
Sep 3, 2015 07:08 PM
