3rd brake light
Old Mar 9, 2001 | 09:02 AM
Fastcamaro87's Avatar
3rd brake light
ok here is my problem, my hatch motor went out the door, so i hooked it up so that it is at the right height, and now it is basically a standard latch, (motor doesnt go up or down), now my third brake light will not come on, it is the one in the spoiler. is there any way for me to hook this up without having to fix the hatch motor?
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Mar 9, 2001 | 10:44 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
The electrical connection to power the HMSL (high mount stop light) is a spring loaded hinge with two spring loaded connectors. It makes contact with a pad on the lower hatch opening. Verify that there is voltage going to the pad. Then clean the contact pad and the buttons with scotch brite or steel wool. Also pull out the HMSL assy and replace any burnt bulbs. Radio Shack has them for $1.99 each. Good luck, Lon.
Vintageracer
Jan 10, 2020 05:33 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
