Best scrach and swirl remover?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
If you could A part numbe rwould be great also. I have a few light scratches that I need to get rid of. I don't want to ruin the paint though. Thanks alot joe. My car is black
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I've always had real good results using Meguire's Body Scrub,, you can get it at Autozone or most of the others. Follow up with a good polish or wax,, whichever you're in the mood for.
My Firebird It Lives Again!!
Your Car Here?
Part Diagrams
[This message has been edited by deadbird (edited March 01, 2001).]
Your Car Here?
Part Diagrams
Car: 86 Z28
When you say polishing pad what do you mean? iDo I need to use a buffer or can I do it by hand? what is th ediffrencse between waxing and polishing?
<font face="Verdana, Arial" size="2">Originally posted by BLACK Z:
When you say polishing pad what do you mean? iDo I need to use a buffer or can I do it by hand? what is th ediffrencse between waxing and polishing?</font>
87 IROC 350 TPI with less than 10k original miles
www.users.uswest.net/~smoyer/iroc.htm
I've had excellent results with the 2 dollar bottle of SratchOut. It comes in a little yellow bottle. Follow that up with some 3M Wax (cheap version of Zymol) and WHOOP, there's no mo' scratches!
89 Formula 305 TBI
160* stat, 200* fan switch, K&N, Headers, 3in Flowmaster (hollow cat) back, pullies, 1.6 full roller rockers, B&M trans cooler, home-made ram-air
3.73 Richmond gears and SLP Zexel Torsen Posi (waiting for install)
89 Formula 305 TBI
You could pay a paint and body shop between $50-$150 to buff your car. You will not recognize it when you get it back I promise.
This is of course if the scratches are only in the clear, if they are past the clear you are basically screwed.
Never tried any of the off the shelf products
If you are comfortable with it you can get rubbing/ buffing compound and do it yourself
Car: 1991 Trans Am
I used 3M swirl remover and followed with 3M wax just the other day. I am totally impressed. I work at a grocery store and I always park away from everything, out by the road. I had four or five of my friends come inside and tell me how awesome my car looked. They all wanted to know what I had used. If you dont want to go to a detail shop, I personally recommend 3M.
1991 WS6 Trans Am
Dark Green Metallic
Camel interior
305 TPI
TH 700-R4, Auto
T-Tops, PW, PL, PM
Keyless entry, alarm
Flowmaster Muffler
Monza Dual Tips
K&N Filter
[This message has been edited by ADMZ24 (edited March 12, 2001).]
1991 WS6 Trans Am
Dark Green Metallic
Camel interior
305 TPI
TH 700-R4, Auto
T-Tops, PW, PL, PM
Flowmaster Muffler
Monza Dual Tips
K&N Filter
