window motor dead
Old Mar 14, 2001 | 11:43 PM
1991redbird's Avatar
window motor dead
I just bought my 1991 Firebird and oneof the reasons I got it cheap was that both pwr windows aren't going up or down. I checked the voltage going to the regulator and its fine. I'm wondering if somebody else had the same problem and can give me some tips on how to replace the window regulators (motors?).
Old Mar 15, 2001 | 12:28 AM
well, found the article in the archives. Looks pretty bad. Did anybody have it done for less money than $400 each side at the shop?
Old Mar 15, 2001 | 06:45 PM
LordDragon's Avatar
The removal and installation is covered in the Haynes Repair Manual for Firebirds. You can get one at your local autozone for like 15 bucks or so I think it was.
Old Mar 15, 2001 | 08:20 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I did my own. $45 for each side plus $5 for nuts and bolts. Total of $95. It not too bad. You just have to get over the fear factor and just do it. After you one side the other side will go alot faster.
90 Firebird SSA (Bone stock 3.1)
Everything Below I've added
Engine: Accel Super Coil, 8mm Accel Ignition Wires, 170 Degree Thermostat, NKG Plautum Plugs, K&N Filter, Flowmaster 80
Suspension: Bell Tech Drop Spindles, Edelbrock PanHard Bar, Lakewood Lower Control Arms, Wonderbar IROC-Z, KYB GR2 Struts, KYB Gas-a-Just Shocks, PST Suspension Polygrapite Bushings All Round, 36mm WS6 Front Sway Bar, 24mm WS6 Rear Sway Bar
Brakes: Cross Drilled and sloted Rotors
Appearance: Trans Am Tail Lights, Trans Am Wrap Around Wing, Trans Am 16" Alum rims, Tinted Windows Rear 90% Sides 50%
Interior: GTA power seats, Overhead console, Power windows, Power locks, T-tops, Sun shade, Pioneer P77DH, Uniden radar detector, Intellitronix - Fuel pressure gauge, Transmission temp gauge. (In pods)
Old Mar 16, 2001 | 10:14 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've done them before; no biggie. The hardest part is working the regulator out of the "way too small" holes in the door. Switching the bad motor for the good motor on the regulator is cake (make sure to lock the sector gear- detailed in the Haynes book).
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 18, 2001 | 02:23 PM
Cool, thanks guys replaced it on the drivers side yesterday. I drilled the living crap out of those 4 rivets that hold the motor and regulator and scratched up all around it. If anybody knows of an easier way to get those things out I'd greatly appreciate you sharing it with me :-). Thanks again
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
neekolzun
Aug 24, 2015 04:59 PM
evan555222
Aug 22, 2015 07:14 PM
