4th gen hatch opener
Old Oct 5, 2012 | 01:32 AM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
so my pull down motor stopped working (big surprise) so i want to make it a regular just pop button. saw a 4th gen looked like it had what i was looking for. what do i need to make it work?? or if there is already a thread please send me in the right direction thanks in advanced
Old Oct 5, 2012 | 02:07 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: 4th gen hatch opener
I'm sure you could get the 4th gen one to work with enough fabrication, but I'm also sure it would be a lot easier to adapt a non-electric pulldown one from an earlier or lower-optioned third gen. Plus the 4th gen ones suck -- the latches aren't made very strong, and the springs are so weak that I usually have to hit the release button 3-4 times to actually get it to come up far enough to actually release when it's below 80 degrees outside.
Old Oct 5, 2012 | 04:38 PM
Car: camaro
Engine: 3.1
Transmission: auto
darn. so 2nd gen then?? or is there a lower year 3rd gen that had it
Old Oct 8, 2012 | 09:07 AM
navy02ws6's Avatar
I'm pretty sure the hatch motor was not available at first...maybe look at some 82-84's next time you're at the jy?
Old Oct 8, 2012 | 10:32 AM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
My suggestion is to just fix it if you can. The factory didn't switch to the pull downs because they wanted everybody to have something cool that wasn't optional. They did it because they got tired of paying for exploded back windows in cold climates. Not to mention that when the glass falls out and the hatch weighs about 200 pounds less, it springs open hard enough to break your jaw. Yeah, I'm old. You'll also have to do some welding to use the early style latch.
Old Oct 13, 2012 | 04:26 PM
Car: camaro
Engine: 3.1
Transmission: auto
makes sense. these damn pull downs are just so damn expensive. and if i pull it from a salvage yard who knows if it will still be good
Old Oct 13, 2012 | 04:48 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
thirdgenranch.com for a used one.
Or TDS for the rebuild kit. http://www.top-downsolutions.com/hatch-pull-down-items
Street Lethal
Apr 30, 2019 12:14 PM
Warlocksirix
Sep 3, 2015 12:26 PM
cam-mike
Aug 24, 2015 07:23 AM
