Hawks RA I Hood
Old Oct 9, 2012 | 03:37 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Hawks RA I Hood
Has anybody made one of these functional? If so, how much work was it? Will it work with the airbox for the RA II hood? These look 100000000000X times better than a RA II on our cars but I 'd like to get a little cold air to the intake. And, don't say "RA I and a CAI" as my heater hose re-route precludes that and I don't think they're of much value, either. Also, I've "searched" to no avail. Pics would be great!
Old Oct 9, 2012 | 07:08 PM
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
Re: Hawks RA I Hood
I don't think there is enough room under the RAI hood to fit the RAII airbox(when it is bolted normally.)
One thing you could do though is rather than it sitting on top of the radiator support...move it back towards the motor more. That might allow it to fit under the hood.
Anyway, you must be looking at too many 82-90 cars with the RAII hoods. They look much better on 91-92 cars.
Old Oct 9, 2012 | 08:05 PM
86F.BiRD's Avatar
Car: 1986 Pontiac Firebird Base
Engine: SBC 350
Transmission: Borg Warner T-5 World Class
Axle/Gears: 4th Gen Rear with 3.73s
Re: Hawks RA I Hood
thats a nice firebird! thats the hood ive been wanting
Old Oct 9, 2012 | 09:50 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Hawks RA I Hood
Charcoal, You have a nice looking car. But I would have to say that the RA I hood looks much better on the '91-92 birds. The lines of the RA I flows with the car.
Old Oct 9, 2012 | 11:48 PM
watajob's Avatar
Car: 92 T/A 'vert
Re: Hawks RA I Hood
Agreed. When I saw this pic, I almost soiled myself! Like a dummy, I set it as my background but neglected to save the pic. Hence, the screenshot.
Old Oct 10, 2012 | 12:49 PM
watajob's Avatar
Car: 92 T/A 'vert
Re: Hawks RA I Hood
So, has anyone done this? Pics?
Old Oct 10, 2012 | 12:55 PM
Car: 1991 Firebird
Engine: 3.1L V6
Re: Hawks RA I Hood
Thank you, Blacksunshine.
He is on CarDomain(don't remember his info though.) I love the look of this car also.
Old Oct 10, 2012 | 01:27 PM
88FormulaKiller's Avatar
Car: 1967 Firebird P.T.
Engine: LS3 4" Strkr 422ci
Transmission: MN12 6 speed
Axle/Gears: 3.73 8.5" 10 Bolt Eaton
Re: Hawks RA I Hood
yes you can make it functional, theres another 91 Vert around somewhere that modified an Ls1 lid with fiberglass and some massaging. looked factory and functioned, however, he had an LSx swap in that car, dimensions would be different in a Gen II car but im sure the idea is the same.
Old Oct 11, 2012 | 12:24 AM
watajob's Avatar
Car: 92 T/A 'vert
Re: Hawks RA I Hood
Anyone know who this might be? A search revealed nothing.
Old Oct 20, 2012 | 10:11 AM
shr00m's Avatar
Car: 1992 Jade Green---Trans Am Converti
Re: Hawks RA I Hood
Twas me... I started with another company's RAII box, but concept is the same. The RAII box is too far forward. I molded together a spare plastic radiator cover, the cut up RAII box, and a 4th gen lid (just to fit the LS1 MAF and have more of a smooth transition).
Using the extra radiator cover allow the box to sit directly on top of the existing one and bolt up using the two middle bolts. I redid when I added the supercharger and it's now pretty much 90% fiberglass with a 4" outlet for the 102mm TB, but I haven't posted pictures of that yet.
Kevin D.
Old Oct 21, 2012 | 10:32 PM
watajob's Avatar
Car: 92 T/A 'vert
Re: Hawks RA I Hood
Thank you very much, sir! 2 more ?'s:
That's about 1" rearward?
Is there anymore foam "sealing" necessary other than what's shown?
An exterior pic would be great.
Thank you again!
Old Oct 22, 2012 | 07:22 AM
Re: Hawks RA I Hood
Superb job on the RA box Kevin.
Old Oct 23, 2012 | 11:36 PM
shr00m's Avatar
Re: Hawks RA I Hood
If talking about the front edge of the radiator cover, it's more about 2" or so. If you mean, 1" farther back then the RAII box I started with, then yes. The lid goes over the base, plus the picture is a little deceiving. Easiest thing to see is that the 'box' starts right where the radiator cover goes flat.
I actually removed the foam after a little bit to try and allow the hood to close a little closer to the front bumper. Wound up taking about 5 years and redoing the box for the SC to determine what was causing the line up issue (hood spring), but I didn't notice any adverse effects.
Honestly it's SO close to the hood that I'm not even sure if the foam is needed. The tubing on the SC made the box raise up just a little bit and the hood was really hard to close.
Eventually (probably another 4 years), I'll throw some playdoh around the lid and get an actually mold of where the hood lays.
Thank you again!
Here's one from last week at CTC:
Here's one before I removed the hood spring:
Here's a few 'unpublished' pics from when I remade the air box. Give's you an idea about how to make something like it.
Old Oct 24, 2012 | 12:42 AM
watajob's Avatar
Car: 92 T/A 'vert
Re: Hawks RA I Hood
Gorgeous car. Fabulous engine. Nice fiberglass work.
I hate you!
Thanks for the pics.
Old Oct 24, 2012 | 10:06 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
Re: Hawks RA I Hood
Very nice car and work there shr00m. Looks calm till you open the hood.
Linson
Oct 24, 2025 02:00 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
jaridjohn
Oct 5, 2015 07:01 AM
