putting ground effects on 86 berlinetta
Old Mar 30, 2001 | 08:36 PM
jester731's Avatar
is it possible to put ground effects off say an 86 RS onto an 86 Berlinetta? if so what modiffications if any need to be made?
1988 IROC-Z Convertible 305 TPI automatic, power everything. has K&N's and an Air Foil
soon to have hooker cat-back( waiting to install)
1986 Sport Coupe / berlinetta
2.8 MPFI V6 5 speed
Old Mar 30, 2001 | 09:45 PM
clemsparks's Avatar
Car: 1983 Z28
Transmission: WCT5
somebody can probably answer this better than me, but...
When I took the ground effects of the '89 IROC parts car, I saw that it had a special mounting flange spot welded along the rocker panel for the side ground effects to mount to. the nose/bumper cover would be changed too. other than that, you may just have to drill a few holes. PITA though
Clem
1983 Z28 with LG4, 5 speed, and (unfortunately) T-tops
1983 Z28, (unfortunately) auto, NO T-tops---FOR SALE---
Looking for a V8, 4 or 5 speed Camaro with NO T-tops (wanna trade?)
Old Mar 30, 2001 | 09:59 PM
Blue502's Avatar
Yes, but you need all the brackets, and like stated above you need to spot weld the bracket under the door. You also need to drill holes for the studs on the fenders, doors, and rear quarter. The front and rear bumper covers are a direct swap. If you have foglamps, you can do like I did and just turn the assembly over and bolt it to the bar above where it currently mounts. The standard nose is shorter, and so are the foglamp brackets. If you do that, your lamps will sit deeper in the grille (like mine). If you want, you can just get IROC/Z28 brackets and mount the lamps normally. I did my swap back in '89, and it was actually quite easy. The worst part for me was that there weren't any parts available in wrecking yards back then, but of its a different story now...
'86 Camaro Sport Coupe
Old Mar 30, 2001 | 10:00 PM
Blue502's Avatar
Oh yeah one more thing. Since my car didn't have gfx originally, I had the freedom to choose, and I chose TransAm side gfx. Much better looking imho, and they go great with the Camaro styling.
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
Thomas
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
Mutillator
Oct 1, 2015 06:05 PM
92firebirdchris
Aug 14, 2015 11:56 AM
