Loose door handles.
Old Apr 3, 2001 | 06:58 AM
DANIELEK's Avatar
Car: Red Rooster
Transmission: M5
Loose door handles.
Both o my handles on the outside are loose.( not the part that is attached to the body but the part that you pull up to open the door)
How hard is it to replace handles or is there a way of just tightening them up a bit.
thanks.
It is on an 89 iroc.
Old Apr 3, 2001 | 08:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Usually the spring is shot/broken. Replacement would be necessary. To do so, the door panels must be removed. Once inside, you'll see that removal is straightforward.
JamesC
Old Apr 3, 2001 | 09:28 AM
JPrevost's Avatar
Car: 91 Red Sled
I wonder if this is a nasty rattle on most of our cars. I know we have plenty of em but I never thought about the door handle. Thanks for the post, I'm going to have to check my handles out and see if the rattle. My car doesn't have any door locks right now (broken into twice) so I'm just going with shaved handles, locks, and antenna. If battery goes dead then I'll just have to pop the hatch with the key and climb in .
, Jon (350 TBI!)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 4, 2001 | 11:45 PM
KlayBuRn's Avatar
i just had my door off, and mine where just nuts that i had to tighten...heh
i didnt have a spring...
Old Apr 5, 2001 | 12:01 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They all have a spring. It's wrapped around the hinge pin that the handle pivots on.
I've replaced mine a couple of times; they're made out of the cheapest stuff that won't dissolve in sunlight during the warranty period, I guess it's some sort of chinesium; the holes all enlarge, the spring wears out, etc. etc. Replacing them does in fact help out the general rattle situation. I just changed the driver's side one (again) a few weeks ago while I had the door apart for something else.
ICON Motorsports
Veaceonee
Sep 29, 2016 08:15 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Buggy Disaster
Sep 17, 2015 05:12 PM
IROCZDAVE (88-L98)
Sep 17, 2015 07:43 AM
