Changing to 16" IROC wheels
Car: 1985 Camaro Sport Coupe
Engine: 305H
I currently have 235/60R14 wheels and tires. I would like to switch to the 16" stock IROC wheels and tires. I have the Spt Cpe model, not the Z28. What do I need to know to do the swap? Do I need wheel spacers? I assume I will need a new speedometer driven gear. How can I tell how many teeth I need on the new gear? If anyone has done this swap or knows what it takes to do the swap I would appreciate it. Thanks
Robbie-Metairie, LA
1985 Camaro Spt Cpe 305H
1997 Camaro SS
Robbie-Metairie, LA
1997 Camaro SS
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
As far as swapping between 14, 15 & 16" wheels that are on a camaro/bird,,, they are all (generally) the same height,,, 245/50/16 is the tire size for the 16" wheel,,, technically,, if you had the original wheels on your car & swapped to this size,, no speed adjustments shoould have to be done
My Firebird It Lives Again!!(Sorta)
Your Car Here?
Part Diagrams
-It's always the last one
Your Car Here?
Part Diagrams
I have the 16" IROC wheels on my Sport Coupe (originally had 15"), and they are a direct fit. You can use the stock rear wheel spacers if you like, I used to, but they got lost somewhere along the way and I've been running without them for a quite a few years now.
One thing to be aware of though is that with the wider wheels on your car you'll feel the ruts a lot more than now if your suspension, especially the front, isn't up to par. If you find you need to redo the suspension, I would recommend polygraphite bushings.
'86 Camaro Sport Coupe
I just read somewhere that the IROC steering gearbox for the 16" wheels had a different degree of turn than the standard 15" wheel model. It supposedly dosen't turn as far, and when I put the 16s on my RS it seemed like they did turn a touch too far. Anybody know for sure?
Car: 1990 RS
Transmission: TH-350
mine seem to turn to far as well, but i have never had a prob. i bought the car from my moms bf and he bought it from his mom. as soon as she rolled of the lot with it she went home and put the iroc wheels on it. its an 89 and they been on there since without a prob.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The IROC does indeed have a different steering box. The stock sport coupe steering box would cause the tires to rub at full lock on the IROC. It may not rub on the sport coupe because the SC sits higher than the IROC which provides a little extra clearance.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Engine: 305H
Thanks for the tips guys. I am going to get some IROC wheels. I just need to either find some used ones in good shape or buy new. Anyone know where I can get some new ones for under $700. $700 is the cheapest I have found yet.
Robbie-Metairie, LA
1997 Camaro SS
Robbie-Metairie, LA
1997 Camaro SS
kah992
Aug 19, 2015 02:55 PM
mustangman65_79
Aug 11, 2015 03:17 PM
