4th gen seats need help on the install
Old Apr 4, 2001 | 09:48 PM
72BuickGSX's Avatar
hi guys just bought a pair of trans am seats out of a wrecked firehawk at the junkyard, putting them in my 86z just how do i go about hooking up the power and the air hoses from the seats, do i need to just cut the plug off the power and hook it up, and split off a vaccum line and run to the seats, any help ?
Old Apr 4, 2001 | 10:58 PM
pookey's Avatar
Try looking under you carpet, some cars want already come equipped with the power seat wiring harness, as far as the vacum hoses, I can't help you, sorry.
Old Apr 5, 2001 | 01:11 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
the compresser should be in the bottom front of the drivers seat...don't cut ANY lines for air...
just get it a good ground and hotwire...
and enjoy
Old Apr 5, 2001 | 09:38 PM
72BuickGSX's Avatar
well the power plug is different thats what im asking, theres 4 wires instead of the two on my orginal seat, on the new one theres your hot and ground and then two grey ones ? , on the air hoses just one tube, anyone???????
Old Apr 5, 2001 | 10:20 PM
Saywhut's Avatar
I'm not positive, but I'm thinking the two grey could be from the lumbar control on the pass. seat, to control the pump, which is under the drivers seat.
There should be a harness on the donor car that runs under the carpet between the seats, that has this wiring, and the hoses to connect the two seats.
If you can get to the donor, get the harness, also get the main plug TO the drivers seat, then get a plug from a thirdgen drivers seat. Splice the last two together, you've just made an adaptor so you don't have to cut any wires on your car, or your new seats. At least thats the way I did mine.
Hope this helps!
Old Apr 7, 2001 | 11:41 AM
Duffster's Avatar
yes...just 1 tube on the airhose.
the switches in the passenger seat operate solenoids which direct the path for airflow.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
