Door protectors around keyholes!!!
Car: Used to drive a camaro
I just picked my 1LE finally. The damn previous owner put those adhesive square keyhole protectors on. Is it save to use a heat gun, like the ones used for hobby airplanes to remove it? I don't want to pull it off cold and see a patch of paint come off with it.?? What's the safest way to remove any residual adhesive left behind? What's the best advise?
make sure your enviroment is warm, heat it up nice; not extremely hot(don't want to melt) and remove slowly.....this "should" work there isn't too much you can do. good luck
hope he marked the price down on the car because of those....jk!
Car: 1986 Firebird
Engine: 2.8 V6
There's a trick you could try, usually used for removing emblems like "FIREBIRD" and "Camaro" and etc...
Buy a roll of fishing line from a sports store. Cut a length of line about, oh, I dunno, 2 feet long? Put on some gloves. Heat the sucker up with a heat gun to make the adhesive gooey. Now, with your gloves on, grab a hold of each end of the fishing line, and pull your hands apart. Bring the fishing line so it touches the surface of the car, right at the edge of the "keyhole protector".
While keeping the fishing line tight against the body of the car, work the line up & down like a saw to dig between the keyhole protector and the car body. This will slice the adhesive in half, and get the keyhole protector off of there.
Then, just use an adhesive remover or a paint prep type of solvent to get rid of the adhesive. Have fun!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
hey i saw a few guys at the junk yard to that for a front windshield. it worked great till they noticed it already had a rock chip in it, and they were pulling the wrong windshield from the taurus. it was the one to the left. oh well i had a good laugh! well i have seen this done. and it works. try it. i am gonna tell my friend that has those dumb things to try it also. i never thought of that but hey if it works then it works!!
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Jarrad
TH-700R4
