DOOR PANEL REMOVAL
Old Apr 15, 2001 | 09:30 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
DOOR PANEL REMOVAL
HOW DO I REMOVE THE DOOR PANELS STEP BY STEP? I NEED TO REPLACE BOTH DOOR LOCKS AND IF I CAN REMOVE DOOR PANELS MYSELF THE LOCKSMITH SAYS I WILL SAVE A TON OF MONEY.
[img]https://www.angelfire.com/sports/niterider/ridednite.jpg[img]
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels, New Leather seats, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
Old Apr 15, 2001 | 10:07 AM
Todd 92 Z's Avatar
First remove the door arm rest it has three bolts, one at the top and two on the bottom. If you have manual windows remove the window crank, with power remove the torx screws that hold the switches to the trim be carefull because some of the screws are fake and are molded to the plastic for looks. do the same with power mirror swith if you have that. you dont remove the switches from the wires just let them hang and remove the black plastic trim from the panel you will have to play with the lock **** a little to get it off the lock rod inside. After that and you get all the screws holding the trim removed the trim should come right off. Next CAREFULLY pry the front of the plastic trim below the window away from the door, you wont remove this its held in place to the panel by plastic fasteners and you just need to pop the front away from the panel. The panel itself is held to the door by plastic fasteners just start on one side and get your fingers behind there and carefully pry it away from the door, do this all the way around the panel.After you get them all, work the panel out of the top trim and your done.
Old Apr 15, 2001 | 10:33 AM
Duffster's Avatar
Car: 2001 Camaro Z28/1995 Camaro Z28
Engine: just a little 5.7(LS1-320/340 RW)
Transmission: SMOOOOOOTH T-56/Auto. . .
Axle/Gears: 3.42 and 2.73
to add to this,
everything Todd said...and you can replace the locks yourself for about 15 more bucks!
there is a rod connecting the lock switch to the lock.
gently remove the plastic clip from the rod by rotating it and the rod will pull out of the lock(this is at the back of the door)
after you do this, the lock will pop out by removing a shim...typically pulling the shim forward will allow you to pull the lock out from the outside.
then simply reverse the ENTIRE process and you're saving more money than you expected.
NO LOCKSMITH! ! !
Duffster (age 31)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
Duffster_Camaro@HOTMAIL.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old Apr 15, 2001 | 02:32 PM
Axle/Gears: Posi
THANKS, NEXT WARM DAY I AM ALL OVER THIS PROJECT. THANKS AGAIN
[img]https://www.angelfire.com/sports/niterider/86camaro.html/ridednite.jpg/[img]
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Out-Cast
Aug 23, 2015 06:33 AM
