Upper door hinge issues
Old Nov 8, 2012 | 09:36 PM
blakej32's Avatar
First post, lurked here for a bit. I picked up a 92 Camaro a few months ago that I fell in love with and decided save from the junkyard. Im going through it peice by peice hoping to do a full restore. From time to time google fails me and reading these threads has saved me some money and time for damn sure.
I am really having a rough time finding the replacement for a drivers side upper door hinge. I took a look at the pin in the bottom hinge and concluded that my sagging was not due to the bottom being faulty. The top needs to be replaced. Has anyone recently replaced one and remember where they obtained said part? Links or a part number to google would be awesome. Knowing my luck it will be welded on or crap and i'll be stuck trying to snag a new door.
bolded for straight to the point people.
Old Nov 9, 2012 | 12:12 AM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Re: Upper door hinge issues
Search for Dorman HELP! brand part number 38401. I have a set I need to swap in. Please post back how it goes for you, I have done hinge pins and bushings before but these look intimidating.
Old Nov 9, 2012 | 07:27 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Search upper hinge pins and you will get an answer.also check out TDS website.
The hinge itself is welded to the door, if the hinge itself is toast, it's usually easier to get a new door. The upper hinge pins can be ground out and replaced, tough job with the door in place, easy with it removed.
Top-downsolutions.com
Old Nov 9, 2012 | 03:33 PM
blakej32's Avatar
That was what I was hoping I needed to do. It looks fairly straight forward. What i'm going to have to do is take the door off, grind out the faulty piece and go from there. I have a bit of metal working experience so it will either go really well or ill break it and have to get a new door or re weld a new bracket.
Old Nov 9, 2012 | 04:36 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
https://www.thirdgen.org/forums/body...ing-lower.html
post #4
Old Nov 11, 2012 | 07:51 AM
stealtht/a's Avatar
If you take the door off its all pretty easy. Getting it lined up again can be a little tougher, just make sure you have a good support or help to put it back on.
The lower hinge bots from the inside so you will want to pull the kick panel.
Old Nov 11, 2012 | 10:16 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Its not that difficult with the door on. I used a cherry picker to hold the door in place. Took me about 2 hours per side to accomplish.
Old Jun 24, 2013 | 09:32 PM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
bringing this back from the dead,
i need to change my pins and bushings badly, what im worried bout is how hard and what tools will i need to get the old bushings out (also pins) and the new ones in?? i have searched and no avail, vids or pics or step by step process would be greatly appreciated
Old Jun 24, 2013 | 09:49 PM
If you buy the deluxe kit from Lon at Top Down Solutions, it comes with some step by step directions.
Old Jun 24, 2013 | 11:26 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Spend the money and get the spring tool. Don't skimp out on this indispensable tool. You will be sorry if you do.
= http://www.top-downsolutions.com/too...or-spring-tool
Old Jun 25, 2013 | 12:04 AM
I tried to save money and not get it. I was able to get the spring out with a short crow bar. No chance in hell of getting that thing back in without it. Ended up forking over the money and had the springs back in place in less time than it took to open the package. I also recommend this:
http://www.top-downsolutions.com/too...e-bushing-tool
It makes getting the lower bushings out a lot easier.
Old Jun 25, 2013 | 07:10 AM
Car: '90 Camaro
Engine: 305 tbi
i already bought the spring compressor, and i already bought pins and bushings from 1aauto, just need to install them. i want to know how and what tool to use to actually get the bushings out. i may just contact lon and see if he'll give me directions or so.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
