The heat inside dosn`t work
Old Apr 20, 2001 | 06:51 PM
camaro4ever's Avatar
(Sorry for my bad languich i´m from sweden)
Hi my problem is:
if I take off the vacumhose( in the engin department,that is locadid on the right side over the valvecover.The tube from the element inside goes too this valve)from this valve ,then i have heat inside the car,but if i put on this the heat whill go avay.
I seams that it is vacum in the hose,that shudet be thear the hose color is black.
And it goes into a kablewire into the firewall my car is a red convertibel iroc -88
I hope somewone understands my languich
and can help me with my problem
PS my mail adress: martin705@hotmail.com
Old Apr 21, 2001 | 05:13 PM
Synergy's Avatar
Well if it does that, then your problem is inside the car. Do any other controls work ? Like the regular "Vent" position or A/C ? If not, then you might want to check the vacuum hose that goes on the side of the plenum and the inside the car to control all your A/C / heat functions. If everything else fails, then I'd take the whole control panel off and look behind it for cracked or disconnected hoses.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
Frozer!!!
Jan 19, 2024 04:55 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
TheExaminer
Aug 26, 2015 04:59 PM
kyle5647
Aug 15, 2015 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
