Started my floor removal
Old Nov 14, 2012 | 06:16 PM
mikesz1984's Avatar
Car: 1984 z28
well i have started to rip my car apart to replace the floors, i bought a cut off grinder and although my air compressor is a bit small, it seems to work pretty good, i will admit i bought a spot weld drill as well, i had my doubts about it, but i am very impressed by the way it works. i will probably pick up a couple of more of them just to be on the safe side. I read on here to use a small drill bit and drill all the way through the spot weld first, and i admit that is the best way to do it. I guess the point of this thread is to say thanks to everybody who recommended the right tools for the job, this will make it quite a bit easier.
Old Nov 14, 2012 | 06:25 PM
Twin_Turbo's Avatar
Re: Started my floor removal
I never drill 1st, I punch mark and use a spot weld drill that is a small hole saw like cutter on a spring loaded bit with a pointy guide pin spring loaded, align the pin press down with the drill spinning and you can "feel" it going through the upper layer of material. A small air chisel and same hammering then usually makes short work. Next with a small 90deg. angle grinder I grind off the residual spot welded upper layer for fresh metal.
This thing!
Old Nov 14, 2012 | 06:30 PM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
I use a 1/2 drill bit....works great.
Old Nov 14, 2012 | 07:01 PM
mikesz1984's Avatar
Car: 1984 z28
This thing!
thats what i have. i tried the center punch, but it still wanted to wander when starting the cutter. as for using a 90 degree grinder, i will only have to do that in a few spots, i am replacing the whole side of the floor with new aftermarket, so no grinding needed there.
Old Nov 14, 2012 | 10:01 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Forget that, those cutters suck.
Cutter use "Winzer 993.02008132"
That is a 8mm, they have a 10mm if the spot welds are bigger, 8mm is most common.
http://www.winzerusa.com/?__event=br...4fab7c2a000965
For cutoff wheels try "Mirka 1226" (1/32)
http://www.abglovesandabrasives.com/...dsh-Off/Detail
Old Nov 15, 2012 | 11:43 AM
85Irocket's Avatar
Car: 85 Iroc
Engine: Don't have one yet.
Transmission: T-5 non wc
Axle/Gears: Disc brake 10 bolt with 373 gears
I use the same style cutter as Twin Turbo and they work great.
Frozer!!!
Jan 19, 2024 04:55 PM
perZ
Aug 15, 2015 01:17 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
