Bumper cover repair
Old Apr 22, 2001 | 05:57 AM
TaKtIcAl's Avatar
Bumper cover repair
Well I scored a 92 bumper cover for $36!!! However it has a dent and a small tear on the top, I know this can be repaired but I want to know how tedious this is going to be if I do it myself?? Would also like to know if you guys have any idea how much a shop would charge to do this?
Old Apr 22, 2001 | 06:47 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
The dent can be bondo'd (yes, bondo can be a verb :P) if its not too deep, otherwise the bondo will crack. Also, you can fix the tear by putting a fiberglass patch on the inside, then bondoing the seam. I recommend scuffing the inside of the bumper with some real rough sandpaper where the patch will go to make the resin stick good.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
Old Apr 23, 2001 | 10:23 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The dent's not too bad; depends on how long it's been dented. You can remove all the metal from the cover, and put the cover in the hot sun. Try to prop the cover on a piece of wood so the wood pushes against the dent, and makes it flat with the rest. A heat gun would help, too.
When I fixed my bumper, I had to do this. I also had to fix some tears; I found a kit by Bondo called "Flexible Bumper Repair Kit". It had the two-part epoxy that bodyshops use, and you applied it like glue. It worked like Bondo, too- it sanded down very easily. Strauss Auto carried it, I don't know if they do anymore, or where else you could find it (this was 5 years ago).
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 23, 2001 | 06:52 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
Definitely use the flexible bumper stuff by Bondo-- don't use regular Bondo or it will crack right back out as soon as the bumper flexes the first time. I have a light dent in my rear bumper cover and have been advised to use a heat gun and pressure from the backside to pop it back out. Good luck.
Old Apr 24, 2001 | 06:29 AM
TaKtIcAl's Avatar
Any idea how much a shop would charge to do this?
CAMAROBEAV
European Region
Nov 18, 2015 06:41 AM
Magman
Sep 12, 2015 11:55 PM
CAMAROBEAV
European Region
Sep 12, 2015 09:34 AM
scottmoyer
Sep 7, 2015 07:06 PM
SG91camaro
Sep 5, 2015 10:27 PM
