Door hinge lube
Old Dec 1, 2012 | 06:30 PM
d1drifter's Avatar
Car: 1985 firebird trans am
Door hinge lube
Ok I just got my door pins replace . I got both side from 1Aauto. Well it's been 2 months and now it's getting cold. What should I use to lube up the hinges. There squeaking like crazy and I don't wanna wear them down.what should I use to lube them . Wd40? Liquid wrench or graphit ???
Old Dec 1, 2012 | 06:36 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Door hinge lube
Some type of graphite, or silicone. Something like that so it won't freeze & clump up when it gets collld outside.
Old Dec 1, 2012 | 06:40 PM
d1drifter's Avatar
Re: Door hinge lube
What type of silicone?
Old Dec 1, 2012 | 06:45 PM
Car: '87 Camaro
Re: Door hinge lube
Spray can. AutoZone, O'Reilys, PepBoys,etc.
Tell them what its for, they'll help get the right stuff : )
Old Dec 1, 2012 | 08:00 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Door hinge lube
i have found that white lithium grease (in a spray can) is good for hinges , linkage , rollers , window linkage & tracks , etc. . i used some today on my hood hinges (CRC brand) . good luck .
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
codeysabatini
Sep 20, 2015 11:36 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
