LIGHTED REAR VIEW MIRROR QUESTION????
Old May 3, 2001 | 04:14 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I JUST FOUND THIS LIGHTED REAR VIEW MIRROR AT THE JUNK YARD TODAY. IT CAME OFF OF A 86 BERLINETTA AND HAS 3 WIRES, ONE BLACK, ONE WHITE AND ONE WITH A RED STRIP ON IT. DOES ANYONE HAVE ANY IDEA ON THE PROPER WAY I SHOULD HOOK IT UP. ON THE BERLINETTA IT WAS WIRED TO THE DOME LITE. I WOULDN'T MIND DOING IT THIS WAY BUT I JUST PAID A SMALL FORTUNE TO REDO MY HEADLINER(T TOP) AND DON'T WANT TO SCREW IT UP. ANY HELP IS APPRECIATED. THANKS
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels, New Leather seats, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
Old May 3, 2001 | 04:22 AM
Jza's Avatar
Jza
The reason it's wired to the dome light is because it's wired to turn on with the rest of the lights you open the door or turn on the interiors. If you want you can run it from one of the other interior lights like the two bulbs under the dash, or you can just leave it off altogether, and have it to where it only turns on and off with the switch.
Old May 3, 2001 | 11:01 AM
Pino91Formula's Avatar
But you still have to run the wires under the headliner
Old May 3, 2001 | 11:04 AM
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Eibach Pro-Kit Springs
Hotchkiss STB
SLP exhuast
SLP Cold Air Induction
CatCo Hi Flo Cats
http://www.geocities.com/MotorCity/Garage/5654/mur91.jpg
and the for ever returning CODE 32
Old May 3, 2001 | 11:06 AM
Pino
91'Formula
LB9 305 TPI 5-speed
WS6 17" wheels
Hotchkiss STB
SLP exhuast
CatCo Hi Flo Cats
http://www.oldsrocket.com\91bird
Old May 3, 2001 | 12:10 PM
Tonyrodz's Avatar
Transmission: auto
Not really-just a little bit on the edge.
When I put mine in I ran 1 wire to a hot lead(fuse panel)I ran the wire under the pillar on the driver side(along windshield) and I used a screw from the visor as a ground--I left the other wire just hanging, by doing that it only worked when I pushed the switch. Once you run the wires just tuck them under the liner(along the edge) and your done.
E-mail me if you have any further questions and I'll try to explain a little better.
Old May 3, 2001 | 01:02 PM
Axle/Gears: Posi
THANKS, I DON'T THINK I NEED TO RUN IT TO MY DOME ANYWAY. I GOT THIS SWEET RED BULD IN THERE AND THE RED AND THE WHITE FROM THE MIRROR WOULD CLASH. I ONLY NEED THE MIRROR FOR READING DIRECTIONS AND STUFF. I GOT THE MIRROR FOR $2.00 BUCKS SO IT'S WORTH A LITTLE TROUBLE. I'LL EMAIL YOU IF I HAVE PROBLEMS.
Old May 3, 2001 | 01:04 PM
Axle/Gears: Posi
I seem to be having trouble posting pics again. I know i am doing it the right way. anyone know what's up?
http://www.angelfire.com/sports/niterider/86camaro.html
Old May 3, 2001 | 05:17 PM
Tonyrodz's Avatar
Transmission: auto
You can change the bulbs in the mirror to make them red too.
Old May 4, 2001 | 07:40 AM
Axle/Gears: Posi
HOW DO YOU DO THAT? THAT SOUNDS SWEET. WHAT SIZE BULB FOR THE LIGHTS?
Old May 4, 2001 | 07:36 PM
Tonyrodz's Avatar
Transmission: auto
Look where the lights are, near the little switch you will see a small slit(notch)stick a small flat head in there and pry it down--it'll pop right out. don't remember which bulb size but you'll see it, just pull up on the bulb.
jaridjohn
Jul 8, 2024 03:49 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Omega
Aug 10, 2015 12:46 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
