Shifter Knob....not OD compatible?
Old May 9, 2001 | 01:03 AM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
Shifter ****....not OD compatible?
ok...i guess this goes here in this forum. Since i have worn a hole right through the leather on my automatic shift **** to the plastic underneath, because i like to keep my hand there for radio controls and such, and its geting progressively worse, i went to pep boys and stumbled upon those carbon-fiber automatic shift ***** for like 35 bucks. I was thinking about it, but then i saw a sticker on it that said "not for use on cars with OD gear" and i have overdrive. Ok, so i cant use it...this may be a dumb question, but what makes it unable to work on a car with OD?
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old May 9, 2001 | 02:13 AM
pookey's Avatar
Not sure if I am right but here goes nothing. When I changed my consule, I took off the shifter **** and saw a piece of plastic that had little ***** on it. I am sure their were 7 ***** on it (for the 7 tranny positions). It maybe that the shifter **** can only handle six because of it size. Just a though.
Old May 9, 2001 | 05:19 AM
Jza's Avatar
Jza
Maybe it's referring to the cars with the OD switch on the shifter **** (like Nissans).
Old May 9, 2001 | 08:40 AM
Duffster@Work's Avatar
John...the overdrive the **** you are looking to purchase refers to the cars with a switch in it...like the Nissans JZA mentioned..
our cars have the auto-unlock button at the top...if you can find a way of shifting without needing that button, you'll be fine.
As for the 7 ***** on the little white plastic rod inside our shifters...that is for structural support, so the plastic doesn't bend, but nice guess Pookey.
Duffster (age 32)
BEAT DOWN HARD 88' Camaro Sport Coupe,
1978 Caprice Classic 305 motor havin'(WITH NO COMPUTER),Torker II intake, Edelbrock 1406,600cfm w/vacuum secondaries,Accel HEI Supercoil/Cap/Rotor Sparkin',84' POS 700R4 Tranny usin', 84' Z-28 Nose clip wearin',
84' Z-28 Hood covered,
AND THE TIRES:
245/60-16 Firehawk SS20 on Firbird rim(1-passenger rear),
235/55-15 BF Goodrich's on CompTA's on Z28 rims(2-on front),
235/60-16 Pirelli P600 w/a curb check or 3 also on Firebird rim(1-drivers rear),
REAR HATCH MASTER OF ALL!!!
DuffsterCamaro@HOME.COM
Owner of the Camaro 0 out of 10 Third-genners approve of, no longer part of the non-existent Iowa crew.
Old May 9, 2001 | 10:25 AM
PhantomTPI's Avatar
Engine: 5.0 TPI
Thanks everyone. That carbon-fiber replacement looks ok i guess, but i just was curious. I dont think i will be getting it. My friend who has a (gag)mudstaing has OD in his car and bought that same shifter...he said it worked fine. Go figure.
OTHER RIDE:
12/14 Options
Stock(for now)
mcfastestZ28
Oct 5, 2015 07:12 AM
ndndndnd
Sep 28, 2015 08:00 AM
