paint for plastic
Old Dec 20, 2012 | 02:05 PM
ransam's Avatar
Car: 88 trans am 72 olds cutlass
Engine: soon to be 5.3 455 olds
Transmission: soon to be t-56 2004r
Axle/Gears: 3.23 3.73
paint for plastic
I am repainting my ta and i want to restore the plastic headlight surrounds and various pieces so everything looks new. What products are everyone using the duplicolor plastic paint or the stuff from sem? Im not sure what color it should be as mine seem to be a little faded. Im guessing semi gloss or satin?
Old Dec 20, 2012 | 02:42 PM
LHernandezJr's Avatar
Re: paint for plastic
I've used SEM products with good results. I believe interior colors are available in only one sheen, but I may be wrong. However, the stuff I used was the correct luster.
FWIW, I used black paint.
For exterior pieces SEM's trim paint works really well also.
Surface prep is the most important part of the equation, as you probably know. And a good adhesion promoter, at least for inside plastics, is mandatory.
Old Dec 20, 2012 | 07:33 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
https://www.thirdgen.org/forums/inte...ic-carpet.html
Old Dec 20, 2012 | 09:54 PM
82tarecaro's Avatar
I did the headlight surrounds with SEM trim black. Like Luis said - it is all in the prep - and the adhesion promoter is a must. Plastic is made of petroleum and paint does not like to stick to it.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 28, 2015 02:28 PM
90formulaVortec
Exterior Parts Wanted
Sep 7, 2015 07:17 PM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
