How replacing the carpet turned into a new paint job
Old Feb 29, 2012 | 12:09 PM
lilnebel's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 V8 TPI
So my new years resolution was to fix a few interior problems with my camaro since it was just sitting i though i could take my time and it would be simple. The carpet had bad mold due to poor weather stripping, simple solution replace the carpet and weather stripping. Well i had to weld some rust holes in the floor pan and since I had to break out the welder and the car was up on jack stands I thought well no better time than now to build subframe connectors. That is the exact point I got the itch to paint the whole car, I have bad ADD so when i get an idea like that its like christmas. I stripped the whole car down and then realized how much work this was going to be, i told my self its too late to put it back together. Now here I am, my plans are to get the car painted white and paint the GFX black just a little contrast, I am going to install black interior as well. originally the car was red with gray interior. here are some pictures of my progress. I will upload more pictures when i have time.
Attached Thumbnails How replacing the carpet turned into a new paint job-10.jpg
Old Feb 29, 2012 | 12:38 PM
Mudluver27's Avatar
Car: 1988 Firebird
Transmission: 6-speed
Axle/Gears: 2001 ss 10 bolt 342's
Re: How replacing the carpet turned into a new paint job
I understand. I started a simple engine/trans swap and now my interior is gutted lol. Was gonna do carpet.... now its rust patching, carpet, seats, headliner, console, wireing, seals, caulking.... OMG lol. The price you pay for a "Good Idea".
Old Feb 29, 2012 | 10:50 PM
383 Power's Avatar
Car: 1982 SC/1984 Z28
Engine: 305 4BBL/305 4BBL H.O.
Transmission: 700R4/700R4
Axle/Gears: 4th Gen 3.23 Posi/3.73 10 Bolt
That's what i'm gonna do. I'm kinda scared to do it, but it'll be nice to send JUST A ROLLER to the body shop. I'm gonna take EVERYTHING out. Wiring, Everything under the hood, Interior EVERYTHING. The only things i'm not going to remove is the K-Member with the suspention attached and the Rear end. Only because I need them to get it to the shop. When i get it back, BAM! New UMI K-Member! BAM! Ford 9" Rear end! BAM! New 383 Engine and Transmission! BAM! New Wiring Harness! BAM! New interior!
Oh, and BAM! Empty Wallet!
Old Mar 2, 2012 | 11:42 AM
lilnebel's Avatar
Engine: 5.0 V8 TPI
Here are some more pictures of my progress.
Cleaning out the seam sealer
More of just removing everything
The lip here is actually rusted through so i cut it off and replaced it with fiber glass
Still have to trim and finish sand after applying glazing putty
After looking at a few post i decided i was going to shave the bumper ground effects and door handles. I am doing it the same way i saw in a post by drilling holes and using short strand bondo filler i will also epoxy the backside of each hole to try to form a cap so it cant pull out
Old Mar 2, 2012 | 09:27 PM
Jennyismetal's Avatar
Car: 89' Camaro RS
Engine: 5.3 Vortec
Transmission: Th400
Axle/Gears: 10 bolt posi
looking good so far. cant wait for the full project to be completed!
Old Mar 3, 2012 | 11:51 PM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Same exact thing happened to me. Went to switch out the engine and ended up gutting the car. Unfortunately its now sat for 10 years or so (health issues) but finally getting around to working on it.
Old Mar 5, 2012 | 09:38 PM
hotshift13's Avatar
Car: 89 Trans Am
Engine: 305 alive
Transmission: slugomatic
From the Shaw I see! Your car will be easy to spray from the pics. I did mine last year and it came out nice. still got to finish some details, but it turned out nice.
Old Mar 5, 2012 | 09:55 PM
82tarecaro's Avatar
The car looks relatively clean. Why would you fix rusted out areas with fiberglass? Do it right and repair it with metal. You are going through all that trouble to paint the car. You will not be happy when the repair cracks and you have to do it the right way.
Old Mar 6, 2012 | 09:27 AM
85_ZED28's Avatar
Car: '85 Z28
Nice work! Not sure about the white w/ black GFX colour scheme though. I've seen it done and didn't like the look, but it's your car!
Old Mar 6, 2012 | 05:06 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
I've got some pics of my 88 in my album if you want to see one in white and black. It looks like that in pics anyway. Both colors are pearl, three stage.
Old Mar 6, 2012 | 07:58 PM
FireInMe17's Avatar
Car: 1990 Camaro RS
Engine: 355 Vortec TPI LT4 Hotcam
Transmission: TH700-R4
Kinda how my project is starting to look....V6 to TPI swap and now I'm getting paint and a whole new interior and complete drivetrain, haha. Looking good though man. Keep it up.
Old Mar 10, 2012 | 06:39 AM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
What kind of welding method are you using..? Mig ? Tig ? As far as white with Black gfx.. Have a friend that did this, lasted a week. He found out that at night, the scheme made the car look like a base-Camaro. Good luck with the build! Stone
Attached Thumbnails How replacing the carpet turned into a new paint job-gcsig2-1.jpg
Old Apr 15, 2012 | 10:23 PM
lilnebel's Avatar
Engine: 5.0 V8 TPI
So I got the car to the booth to spray started to spray the car. sprayed sealer then base coat and then clear after the first coat of clear in some areas [where i had touched of the primer when i was doing body work] the paint turned cream color but there were no other defects. I am clueless as the what happened. any help would be appreciated.
Old Apr 15, 2012 | 11:29 PM
88camaroscv6's Avatar
Car: 1989 Formula, 1988 Camaro
Engine: Vortec 350 TPI, 2.8 V6
Transmission: 700r4, 700r4
Axle/Gears: 4th Gen 3.43 Posi, 3.43 Open
^^ yeah im with him on that too, i know someone who painted their gfx black and it looks pretty bad, keep the gfx body color, they resemble a higher trimed car, why would you want to hide them with black paint, it also makes people think that its a cheaply added on body kit with someone who was too lazy to paint them body color, please do not paint them black you will regret it
Old Apr 15, 2012 | 11:39 PM
jimmy_pop15's Avatar
Car: 1986 Z28
Transmission: 700R
Axle/Gears: Stock
bleeding from the hardener in the primer. What kind of primer and body fillers did you use?
Old Apr 16, 2012 | 05:34 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
i agree completely. It looks tolerable with the 85-90 GFX, but only because the 85-90 gfx are a lot more subtle than the 91-92 gfx. And to get the 85-87 Z28's to look right with different ground fx, they match it to the wheel color and get a really elaborate stripe package to try to blend it into the body.
The 91-92 parts are just really large and aggressive looking, and if you paint them black it just has that import with a body kit that doesnt match look.
If you like the look go for it, but I think it just has a strange look since the 85+ ground fx are so integral to the lines of the car. They dont need to be hidden or emphasized. Keeping it body color makes the car look much more clean.
Old Apr 17, 2012 | 10:53 PM
lilnebel's Avatar
Engine: 5.0 V8 TPI
I want to ask why its not right to fix the rear quarters with fiberglass. There is always more than one way of doing something and also a right and wrong way of each method. I have used fiberglass with metal before, fiberglass and resin only adhere to porous materials, steel is porous, its all about the prep. I understand that rust can be a big issue if its not all taken care of it can push the fiberglass out and cause cracking but then its all back to the prep.
This is where the primer from a spray can bleed through on the clear for some odd reason. Its the off white strip on the top of the door.
As of now i have the doors and fenders sprayed hopefully in the next few days i will have time to finish painting.
Old Apr 17, 2012 | 11:10 PM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
Looking good! I think thirdgen cars look best one color, I have the two tone and can't wait to get a paint job. Maybe some strips here and there. But it cool when everyone has their own style.
Old Apr 18, 2012 | 06:56 AM
haps's Avatar
Car: 91 Z28
Axle/Gears: Stock
Yep.
Spraybomb primer?
Steel is porous?
Old Apr 19, 2012 | 01:40 PM
lilnebel's Avatar
Engine: 5.0 V8 TPI
Ya i used spray bomb primer lesson learned. and yes steel is porous that is why paint and filler putty and any thing else that is designed to seep into the surface and grab onto the surface sticks as well as it does.
Old Apr 19, 2012 | 02:14 PM
Canadian Girl's Avatar
Wow car is looking amazing.... can't wait to see the final product
Are you still keeping it two colors?
Old Apr 19, 2012 | 11:35 PM
lilnebel's Avatar
Engine: 5.0 V8 TPI
here are some more pictures. I am going to keep it two colors. i wont be able to finish the GFX till this weekend and i wont be able to finish the spoiler and mirrors for a bit as i dumped sealer into my basecoat thinking it was leftover base coat. and I am back to being a broke college kid after buying the paint and supplies to go with. I wont be able to sand and buff for about a week. but in the mean time i will be assembling the whole car.
Old Apr 20, 2012 | 11:41 AM
lilnebel's Avatar
Engine: 5.0 V8 TPI
I got the car back home last night and now i have to start putting it all back together. Is there any guides or instructions? i took pretty good notes but i want to make this process as easy as possible.
Old Apr 20, 2012 | 08:03 PM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
Dynamat or an equivalent, start there ... Stone
Old Apr 24, 2012 | 09:06 PM
lilnebel's Avatar
Engine: 5.0 V8 TPI
Updates..
Old Dec 8, 2012 | 08:10 PM
ZZ3 Z28's Avatar
Car: 1986 Z28
Engine: ZZ3
Months later, what does it look like?
Old Dec 16, 2012 | 10:04 AM
carlos64030's Avatar
Car: 1991 Trans Am GTA
I'm curious to see what progress has been made as well.
Old Dec 16, 2012 | 10:20 AM
89 iroc convert's Avatar
Car: 1989 iroc convertible
Engine: 305 tpi
Transmission: 700 r4
looks good !! what do u guys do as far as the under carraige if your going that far why not red0 it to ? do ya low pressure blast it then go black ? or the nasty under coat? even on the rebuild shows on tv very few do anything with the undercarriage andif they do it dont show prep or finish paint vs undrcoat?
Old Dec 16, 2012 | 05:46 PM
91rs-t-tops's Avatar
Car: 91 Camaro Rs
Engine: 3.1 v6
Do they just make a patch panel for the driver side floor pan on the very front? That's the only bad spot in my car
Old Dec 17, 2012 | 01:05 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Axle/Gears: 2.73/3.23
Yeah sorry, but not a fan of the black GFX on a white car.
Old Dec 17, 2012 | 05:33 PM
blakecharles's Avatar
looking good!!!
Old Dec 20, 2012 | 10:57 PM
Car: 91 Camaro Rs
Engine: 3.1 v6
Hey Quick Question
My Wheels on my 91 rs have in the center cap crager on them. they are not stock... Well I cant find the pattern of that style any where. But they look just like Weld Racing Pro stars. They are identical to the welds i should say a mag wheel Any body know what they may the style of them be called.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
Fronzizzle
Aug 9, 2015 01:15 PM
kyle5647
Aug 7, 2015 03:08 PM
