Door closes but still have issues.
Old Dec 20, 2012 | 03:41 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
I had a fellow member check my door for play in the hinges and they were fine. When i close the door with the window up it hits the top of the drip edge of my ttop. There is a small gap at the top half of the door too. what could cause this?
Old Dec 20, 2012 | 03:52 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Re: Door closes but still have issues.
I had the same problem I believe. Except for the door gap.
There are adjustments that allow you to limit how far up the window goes.
Here is a picture I took and labeled, when I had my door all apart. It has been a while but I believe adjustment number 8 and 3 limit how far the window can be rolled up.
Old Dec 20, 2012 | 04:29 PM
Car: 1984 T/A
Engine: LQ4
thanks ill try that. I just need to drop the back top part a tiny bit
Old Dec 20, 2012 | 07:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Try to adjust the T Tops.
Old Dec 20, 2012 | 07:46 PM
Car: 1984 T/A
Engine: LQ4
thanks Ill try that but i still have the issue with the gap and the little plastic piece. The little shiny part of my striker.....does that mean something is wrong?
Old Dec 20, 2012 | 07:56 PM
mantaguy's Avatar
Engine: 5.0 EFI
I know you said the hinges are OK but,I think your hinges are your problem,it sounds like your door is falling to the point were it is hitting the striker low.These doors are really heavy!!!
Old Dec 20, 2012 | 08:10 PM
mantaguy's Avatar
Engine: 5.0 EFI
Give this a look
Old Dec 20, 2012 | 08:51 PM
Car: 1984 T/A
Engine: LQ4
Thanks for the info. should I adjust the striker? I guess ill replace the hinge pins and bushings
Old Dec 20, 2012 | 09:06 PM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
see my passenger door has bad hinges but also while driving down the road it will pop open unless you slam it and lock it
Old Dec 20, 2012 | 10:07 PM
mantaguy's Avatar
Engine: 5.0 EFI
Not sure!!but it wouldn't hurt,I would check the striker first,then the door.
Old Dec 21, 2012 | 12:21 AM
86_irocz-28's Avatar
Car: 86 Iroc-Z28
Engine: 5.3
Transmission: 4l60
I had the same problem i unbolted the bottom hinge of the door and loosen the top one move the bottom of the door down and in youll have to take the kick panel off and the fender. Hard to do without two people one to loosen/tighten the bolts and one to hold the door down, up, to the side, in, out
Eric2ndGen
Nov 5, 2015 01:51 PM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
tecustomz
Aug 16, 2015 02:28 PM
