new gm or reproduction front bumper
Old Dec 10, 2012 | 04:04 PM
mac86's Avatar
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
which should i get? a new GM bumper cover : http://www.hawksthirdgenparts.com/pr...2C-New-GM.html
or a reproduction? : http://www.hawksthirdgenparts.com/pr...roduction.html
what are the differences
Old Dec 10, 2012 | 06:00 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: new gm or reproduction front bumper
One was an original GM part, which will probably have the best fitment.
The other is a re-engineered part. Either reproduced from original GM molds, or new molds produced from an existing bumper. Fit and finish is questionable.
Its like those aftermarket hoods. They never quite fit just right. Corners too high, etc....
I'd rather go to a junk yard and find a good, used bumper that isn't beat up over a repro bumper. Repro in my opinion should be a last resort because you either can't find a new OEM bumper or a good used bumper.
Old Dec 11, 2012 | 02:15 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Repro body parts are generally junk as far as fit and finish -- if you're on a budget, best bet is a used original one.
Old Dec 12, 2012 | 04:27 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I pulled a repop front bumper from an 85 trans am, but I wouldn't sell it as it had lots of curves and warpage which was obvious when installed. It was clearly a less stable material.
I agree with above, original bumper covers are always best, even if they need some repair.
Old Dec 12, 2012 | 09:14 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
You can never beat the fit of OEM.
Old Dec 19, 2012 | 07:53 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
dont go cheap if you have the option to go stock. too many fitting issues with aftermarket.
you'll end up regretting it and buying stock eventually and now you've paid twice.
just get GM and move on
and before spending money on a 2012 gm bumber, try the junk yards. an original bumper is the garuntee best bet for best fitting. but otherwise yes new GM should hopefully be just as good but 3 times what you would pay from a junk yard find.
goodluck
Old Dec 19, 2012 | 08:01 AM
stealtht/a's Avatar
New 2012 GM bumper? Where are those?
Old Dec 19, 2012 | 10:07 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
dont get repop you probably have to mod the bumper so you can have the emblem fitment for the gap in between the bumper and hood tends to be terrible. and many other problems
Old Dec 19, 2012 | 10:20 PM
GTA50's Avatar
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
Go GM all the way.
As an example, after my wife's '94 Firebird was hit, the body shop used a reproduction bumper cover and every time I have to look at that car, it irritates me no end. I will find an original at some point and replace the offending part.
Old Dec 20, 2012 | 06:39 PM
Spaceboy1980's Avatar
Car: 1990 Camaro RS
Engine: L31
Amazon Amazon
Where I bought mine, OE GM part. Couldn't believe they had it!
Old Dec 21, 2012 | 04:23 AM
stealtht/a's Avatar
I'm always amazed how much NOS body parts there are for Camaro. I'm so 'bird oriented that I forget about stuff. Much harder to find a NOS firebird bumper cover!
If I had a Camaro , I would definitely pay for NOS or used original instead of a repop.
1992 Trans Am
May 10, 2023 07:19 PM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
mikey8494
Aug 22, 2015 07:57 PM
Wylecoyote08
Aug 22, 2015 01:58 AM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
