Refreshing the trim around rear hatch?
Old Dec 28, 2012 | 02:16 AM
haro_is_king's Avatar
Car: 1989 camaro iroc-z
Engine: L98 350 5.7 bored 0.30 over
Transmission: 2400 stall lockout
any ideas or techniques to freshen up the black metal trim around rear hatch glass? mine is a little faded/rusty. thanks
Old Dec 28, 2012 | 07:52 AM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
Re: Refreshing the trim around rear hatch?
Same thing is hapening to me and everybody else . best thing to do is remove the trim and bead blast. or a cheaper method is wire wheel. then respray and re install. thats the rout i'm going . quick fix is leaving them on the car and sand, or wire wheel , but first time you hit the glass you'll be sory! tape tape tape ..If its pitted bad from rust best thing to use is duplicolor truck bed liner in a spray can . practice first it comes out of the can rather fast and heavy. it will give it a nice uniform pebble effect . this will hide all the pitts LITE COATS 10 min dry between ......... its also great for cleaning up wheel wells . good luck
Old Dec 28, 2012 | 09:32 AM
Camaro0605's Avatar
Car: 1991 RS
After I got mine cleaned up I painted it with SEM trim black out of the rattle can. Came out real nice. I just taped up the glass.
Old Dec 28, 2012 | 10:56 AM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
https://www.thirdgen.org/forums/auto...tal-hatch.html
https://www.thirdgen.org/forums/auto...make-over.html
Old Dec 28, 2012 | 11:29 AM
thanks for all the informative and responses, and links.......solved !
Old Dec 28, 2012 | 01:04 PM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
This is good info. The trim on my TA looks good, but the Camaro is a differant story.
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
madsv1000
Aug 20, 2015 06:45 AM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
z28addict8490
Aug 7, 2015 08:48 PM
