my wiper arms hit my hood??
Old May 13, 2001 | 06:27 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
my passenger side wiper arm hits my hood as it wipes. Has anyone had this problem. And how did you correct it?
82Z 305 w/comp 270 magnum cam,Edelbrock Performer RPM,Holly 1850-4,serpentine belt drive.TH700R4 w/B&M holeshot 2000 converter,& megashifter.1LE front brakes, 9bolt 3.27 w/1LE rear brakes.Aluminum driveshaft,boxed rear susp.poly everything,IROC swaybar+wonderbar. 70mph@2200rpm ASE Master Tech plus L2
also recently obtained a
'69 chevelle SS396 w/Turbo 400,3.31 posi,11.0 to 1, headers,etc. Latest project car,'86 IROC stock 305TPI hit on left side,but not too bad
Old May 13, 2001 | 05:18 PM
nestz28's Avatar
Mine we doing the opposite, the drivers side wiper was going about 6 inches off the side of the car, it turned out that the shaft for the wiper arm was stripped and the wiper was not properly aligned. I just bought a whole new wiper transmission from the motor to the blades at a junkyard for $30.
Old May 13, 2001 | 06:08 PM
Camarokid01's Avatar
I have the same exact problem with my passenger side wiper arm hitting the hood I haven't tried to fix it really but I think there is a way to adjust the hood upwards. Open the hood and look near the the back of the fenders (underneath the hood) there should be little black ****/screw type things that you can't screw and adjust the hood up a bit. Not sure if that will help but it's worth a try.
Old May 14, 2001 | 04:56 PM
GearHead1973's Avatar
Check to see if the arm is bent and that the plastic stop below where the wiper rests is still in place and not broke off thats how mine got bent.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
