battery box rust repair
Old Dec 30, 2012 | 05:47 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
ok so i need to replace my battery box since its all rotted im making my own battery tray an i wanted to know how to make the new one not rot i was told if u sit the battery in a plastic tray it wont rot is this true ???? if this is true i was gonna find one from a newer gm car an fab it into the new battery tray im also gonna put at least 2 coats of por 15 when the new tray is welded in
Old Dec 30, 2012 | 06:36 PM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
Re: battery box rust repair
a plastic tray will help alot. what causes it to start rusting is if the battery leaks some of the battery acid onto the tray it loses the rust proofing it had. were the acid touched it it happened to me after i replaced the tray
Old Dec 30, 2012 | 08:24 PM
Engine: LR4 4.8
I was wondering if newer gm cars have plastic battery boxes that would work in a 3rd gen an if so what kind of newer gm cars should i look for
Old Dec 30, 2012 | 09:15 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
I knew I should have cut the battery trays out of the last car I had as the trays whaere in awsome shape. Id go with the metal personally as the battery is alot of wieght and the fact the car moves and shakes I think it will take more abuse then plastic
Old Dec 31, 2012 | 11:33 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
some people install the 4th gen camaro coolant tank which is also the batery tray. it also get rig od the clutter in the engine bay
Old Dec 31, 2012 | 06:46 PM
Engine: LR4 4.8
Yea i am putting in new metal i have the old tray out already just waiting to pick up new sheet metal when i get the money im gonna por 15 when it is then i wanna find a plastic box to sit it in since acod doesnt melt it.
So you are saying 4th gen trans am have plastic trays/boxes i will check that out when i go to the bone yard there are a couple at a local pick an pull
Old Dec 31, 2012 | 08:39 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
New metal + POR 15/similar product + truck bedliner (spray-on Bed Armor may work). That thing should never rust again. There is also a product called Battery Mat that supposedly absorbs the acid and converts it into something safer.
Look for Dodge and the like... They use full plastic trays. Doesn't have to be just GM. I know that if you get something from a Dodge, you'll probably end up cutting it somehow, however, since most of the batteries in those are bigger. Make a cardboard template of the bottom of the battery and take it with you to find out what may or may not fit.
Old Jan 1, 2013 | 12:55 AM
lmidden's Avatar
Car: 1987 camaro sc
Engine: lg4 305
the 4th gen battery tray is also the 4th gen coolant tank
Old Jan 1, 2013 | 12:04 PM
6SIX6's Avatar
Car: 89 IROC
thats a good point as if your tray is rotten you can do the 4th gen coolant tank mod and clean up some of your engine bay at the same time. You can see mine in this pic before I trimed it up to fit perfect
Old Jan 1, 2013 | 12:35 PM
kitt23's Avatar
i got a new battery trey for 45 shipped and had it welded in. then i POR-15 it underneath and in engine bay
Old Jan 1, 2013 | 03:01 PM
Engine: LR4 4.8
Yes i see how the coolant overflow tank sits off to the side i like that a lot im guessing the battery sits right on top of it does it have to be a 5.7 4th gen 93-97 or a ls-1 98-02 or do all 93-02 have the coolant overflow tanks like that.
An also what kind of dodge like trucks or do all dodge models have plastic trays i dont mind if i have to cut it since im making my own an had a feeling i would have to cut one to make it fit
Old Jan 1, 2013 | 04:02 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I used a battery box made for a boat, works well for stopping acid rust.
Old Jan 1, 2013 | 09:00 PM
Engine: LR4 4.8
Yea but u dont find boats in a bone yard lol but thanks for the info
Old Jan 1, 2013 | 09:05 PM
Engine: LR4 4.8
Ok so noticed the 4th gen coolant overflow tank sits on the right side but my battery sits on the left. on the other side is the mounting bracket for the air filter housing does the 4th gen tank bolt up on the left ????
Old Jan 2, 2013 | 12:50 AM
6SIX6's Avatar
Car: 89 IROC
Any 4th gen will have it regaurdless of the year. I assume you can use it on either side it just means either the battery hold down is towards the front or rear of the car. Ive seen it in peoples firbirds / trans ams but I cant recall on switch side its on
Old Jan 2, 2013 | 04:37 PM
Engine: LR4 4.8
Yea im gonna go to a local bone yard tomorrow to get stuff for the wifes car there's about 3 of them there not crushed or torn apart yet so ill look an see doesnt matter if its a 6 cyl car either right ????
Terrell351
Jun 13, 2021 01:13 PM
Street Lethal
Apr 30, 2019 12:14 PM
LittleFranks
Aug 20, 2015 03:55 PM
Dialed_In
Aug 20, 2015 01:45 PM
midias
Aug 15, 2015 05:07 PM
