Found rust holes here
Car: 87 Iroc Camaro
Engine: 350 Vortec TPI
Transmission: T56 Magnum
Axle/Gears: 10 Bolt 3:73
Are rust holes where the spare tire sits a common problem with these cars? Any ideas on how to fix this would be appreciated.
Thanks in advance!
Thanks in advance!
Engine: 4++,350 & 305 CIs
Re: Found rust holes here
Yes. Cut it out and weld in a new patch panel. Don't 4get to prep and paint it properly.
Do a search and check with a local known good body shop to see what you'll need.
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Exactly. If you take a pic of the area you need I can see if I got a parts car around here with a good piece for you on the weekend
