Installing my megashifter but I have a Question?
Old May 24, 2001 | 06:16 AM
purpleworm's Avatar
I started installing my megashifter last night and I have got to bolting the shifter down. It tells you to drill 2 - 9/32 holes and then bolt it down. My question is which bolts do I use. The ones that originally bolted the old shifter are too small for the holes I drilled. I think i am just going to pick up 2 bigger self tapping bolts.
I have found it pretty easy up to this point but it seems like a lot of it is mickey moused. I particularly don't like the whole taping the park cable closed idea and just having it float in there. I hope to finish it up tonight. Anything you can tell me would be great.
91 Z28 Camaro
305 TPI
Flowmaster 3" exhaust
700R4 with 2000 Stall and shift kit 3.42 rearend
One sweet sounding system
Old May 24, 2001 | 12:49 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Yes do it your way.......I did mine and found that you follow directions to a certain point and then do what you think is right.
Brian
1989 Camaro RS
305 TBI in process of Rebuild
Old May 24, 2001 | 04:25 PM
Cosmik Debris's Avatar
I thought the correct bolts came in the kit.
Old May 24, 2001 | 05:42 PM
odin65's Avatar
<font face="Verdana, Arial" size="2">Originally posted by purpleworm:
</font>
Mickey moused is the perfect description of the whole shifter, that's why I sent mine back and bought a Quarter Stick.
Old May 25, 2001 | 06:19 AM
purpleworm's Avatar
I was dissappointed to have to hack at so much but I think it will turn out alright. I think I have the shifter back a bit too far but I can deal with that. I just couldn't handle the factory one anymore. Anything is better than that!
91 Z28 Camaro
305 TPI
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
