need factory fog light toggle switch
Old May 25, 2001 | 04:55 PM
blackstripes's Avatar
does anyone have this item. I have a '92 camaro and i would need the switch, the mounting bracket, and the wires running off of the back. I'd buy it from you if you could spare one.
--Pat
Old May 25, 2001 | 06:00 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Before you go out and buy the whole wire harness, remove the cover where the fog light switch would normally be. Check to see if there is a wire harness behind the cover, if so all you would need is the toggle switch. It can be easily had at your nearest GM dealer. Hopefully someone on this board can help you with the rest.
Old May 25, 2001 | 06:09 PM
no luck behind the cover, i need the whole thing...
--pat
jaridjohn
Jul 8, 2024 03:49 PM
TheExaminer
Aug 26, 2015 04:59 PM
fonzie85
Aug 13, 2015 11:50 AM
mustangman65_79
Aug 12, 2015 06:39 AM
Omega
Aug 10, 2015 12:46 PM
