Headlights quit working???
Old Jan 23, 2013 | 01:39 PM
Jk_Under's Avatar
Car: 91 Camaro RS, 84 2.8 5speed
Engine: 305 5.0L
Transmission: Auto, 5 speed
Okay, so my headlights finally gave out, I was driving(at night of course) and when I hit a bump my lights would flicker off, and i had to turn my brights on for them to come on, and now none of the headlights work, what should i do?
Old Jan 23, 2013 | 02:24 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
Re: Headlights quit working???
First thing I'd check is the headlight fuse. Bad fuse = no headlights. Could have just gotten wiggled loose by the bump. If the fuse is good, I'd check for voltage from the headlight switch on your dash.
Old Jan 23, 2013 | 02:31 PM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
What he said, could be the dimmer switch as well.
Old Jan 25, 2013 | 06:18 PM
Jk_Under's Avatar
Engine: 305 5.0L
What fuse is it?
Old Jan 25, 2013 | 06:56 PM
FooFighters92's Avatar
Car: 1992 Firebird & 2009 Nissan 370Z
Engine: 305 TBI
Transmission: W.C. T5
Axle/Gears: 4th Gen Posi, Disc Break/3.42
Originally Posted by Jk_Under
What fuse is it?
Get under there and look. They are all labeled, you should be able to tell which one is for the headlights.
Old Jan 26, 2013 | 09:41 AM
navy02ws6's Avatar
What fuse is it?
The headlight fuse
Should be labeled "HDLMP" or "HDLGHT" or something similar on your fuse block under the driver's side of the dash.
If you can't read the labels, check the owner's manual. If you don't have an owner's manual, do a google search.
Old Jan 26, 2013 | 11:22 AM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
check your fusible links, they are wires coming off the starter i had this exact same situation happen to me, things to buy to fix those the right way..
heat shrink
fusible link wire from autozone
dykes/ wire strippers
and something to put on the end of the wires to plug back onto the starter
a little bit of time too
Old Jan 26, 2013 | 05:16 PM
Jk_Under's Avatar
Engine: 305 5.0L
My links look fine, i'm focusing on the dimmer switch now, but i'm confused, if the dimmer switch went out, why are my sidemarkers(amber side and front lights) my dash gauges and all lights but the 4 headlights still working?
Old Jan 26, 2013 | 05:17 PM
Jk_Under's Avatar
Engine: 305 5.0L
oh and there is no headlight fuse under the dash, none of my fuses are blown either.
P.S. I'm not trying to be annoying guys, its just, this is the only car i own, and it gets dark fast right now.
Old Jan 30, 2013 | 08:51 AM
Jk_Under's Avatar
Engine: 305 5.0L
Anyone with advice? All of my other lights work, all the interior lights, and amber sidemarkers, and brake lights work, just the headlights don't.
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Fronzizzle
Aug 19, 2015 01:36 PM
pigpete
Exterior Parts Wanted
Aug 15, 2015 07:56 AM
92camaroJoe
Aug 13, 2015 06:07 AM
