outer window sweep bolt/screw
Old Jan 23, 2013 | 03:56 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
I am going to start replacing weatherstripping on my car on monday. I was looking at whats left of the hardware and seals and saw that all but 2 or 3 of the outer door window felt strip screws were missing. Does anyone have an idea as to what size these screws are so I can go pick some up? Due to my lack of advance planning I wont have time to order them, so i have to source them locally. Any help would be greatly appreciated.
Old Jan 23, 2013 | 07:28 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: outer window sweep bolt/screw
Do you have a pic,don't know what hardware your looking for.
Old Jan 23, 2013 | 08:31 PM
82tarecaro's Avatar
Hawks sells these.
http://www.hawksthirdgenparts.com/pr...ping-Bolt.html
The earlier cars had phillips head screws but those should be appropriate for your car if it is the one in your sig.
Old Jan 23, 2013 | 08:37 PM
mantaguy's Avatar
Engine: 5.0 EFI
mine had the screws!!!
Old Jan 23, 2013 | 09:31 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
pull one out match it up ,use stainless
Old Jan 23, 2013 | 10:17 PM
gt4373's Avatar
Transmission: 5-Speed Manual
They Can Be Purchased In Just About Any Hardware Store Just Take Out One Of Your Old Ones And Match It Up
Old Jan 24, 2013 | 01:58 PM
fyrebird68's Avatar
Originally Posted by 82tarecaro
Hawks sells these.
Yow - a buck apiece!
I'm with old blue 9 - hit the hardware store.
Also saw a box of 100 phillips flathead stainless self-tappers (1/4") on ebay for $6.
Old Jan 25, 2013 | 06:52 AM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
I think there are black ones available at the chain auto stores like Auto Zone, Advance, etc. Not as good as stainless but lots cheaper and will last as long as you don't bugger the finish off when installing.
Old Jan 25, 2013 | 04:35 PM
mantaguy's Avatar
Engine: 5.0 EFI
The guys spending a lot of money replacing his weatherstripping,I don't think he's worried about spending a couple extra bucks more on the proper screws.
Old Jan 25, 2013 | 05:16 PM
Veaceonee's Avatar
The driver side has 3 screws holding it in
.the passenger side has all the bolts. Is it screws or bolts? What size? I dont mind spending a little extra to do it right.
Old Jan 25, 2013 | 05:24 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Hex head screws.
#8 x ¼" (or, just match length to what you have already) iirc. A washer head or, regular pan head phillips works just the same. They don't have to be a tek (self drilling) screw, like in the hawks link, either.
Old Jan 25, 2013 | 07:55 PM
tavert91's Avatar
Engine: LB9 5.0 TPI
Transmission: 5 SPD
I believe the originals are black oxide and not stainless steel. I would still go black no matter where they are sourced and they will be less expensive than SS.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
