84 trans am door sag
Old Jan 23, 2013 | 08:06 PM
Alex Waller's Avatar
Car: 1984 Trans Am
Transmission: 700r4 automatic
just as the title the driver door is sagging and idk what to do to fix that please help
Old Jan 23, 2013 | 08:16 PM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
Re: 84 trans am door sag
Check the bottom hinge of the door, there should be a brass bushing as part of the hinge. It may be worn out or missing, and need to be replaced. I know mine popped out and it made the door sag an inch or so.
Old Jan 23, 2013 | 08:24 PM
Car: 1984 Trans Am
yea ill take a look tomorrrow but what happen to me i had rust at the bottom door and messed it up so the door sag is really bad cuz the door trim
Old Jan 23, 2013 | 08:29 PM
toomany's Avatar
The only real way to correctly fix the sagging doors is to rebuild the hinges.
TDS has a nice kit to do it.
http://www.top-downsolutions.com/Bod...ody-(greasable)
Old Jan 23, 2013 | 08:31 PM
malcom2073's Avatar
Car: 1987 IROC-Z
Engine: 383ci SBC
How did rust at the bottom of the door make it sag? And what do you mean "the door sag is really bad cuz the door trim"?
Perhaps some pics are in order?
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Many questions have been asked and answered on TGO. A search will often guide you to posts that will be helpful.
JamesC
Old Jan 23, 2013 | 08:33 PM
Car: 1984 Trans Am
i hate do doors they suck
Old Jan 25, 2013 | 07:07 AM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Just replaced mine with the Top Down Solutions kit and the sag is gone. Very happy with the solution and Lon, a participant on this site, was a great help whenever I had a question. He can be contacted at topdownsolutions@yahoo.com or www.top-downsolutions.com. replacing the pins and bushings made a world of difference on my 91.
Old Jan 25, 2013 | 07:38 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
"i hate do doors they suck"
Seriously considering as my next signature.
Old Jan 26, 2013 | 03:20 PM
toomany's Avatar
Before doing the lower doors on my 82, the bottoms had rusted to the point that the ground effects were catching on the rocker panel. Made it seem like they were sagging. This could be the problem the OP is having. In that case new pins may not solve anything. I know on my car the hinges were still fine.
Old Jan 29, 2013 | 10:36 AM
Car: 1984 Trans Am
its rusted under the door panel to the part of the its hitting the rocker pannel
Old Jan 29, 2013 | 11:16 AM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Pictures would help.....
Old Jan 29, 2013 | 11:17 AM
Car: 1984 Trans Am
Ill be taking some pics soon
Old Jan 29, 2013 | 11:58 AM
Car: 1984 Trans Am
Old Jan 29, 2013 | 12:15 PM
naf's Avatar
naf
Time to pull a new door off a junker, preferably one that's still tight in the hinges.
Old Jan 29, 2013 | 12:18 PM
Car: 1984 Trans Am
i wish been to every junkyard in the area they have nothing at all
Old Jan 29, 2013 | 12:24 PM
naf's Avatar
naf
Be patient and try again in a few. They're still showing up with fair regularity.
Old Jan 29, 2013 | 12:26 PM
Car: 1984 Trans Am
I went to a few body shops to have it fixed and they gave me dirty looks and wouldn't even give me a estaminet
Old Jan 29, 2013 | 12:31 PM
NotsosleepyZ's Avatar
Car: 89 Firebird
Engine: 5.7
Axle/Gears: unkown
i had a solid tbird (no rust) wit the same problem, didnt wanna spend money on new hinges so i just stuck a 1/2 inch socket in there and sprung the hinge up, worked great, sold it to a buddy and its still fine after a year
Old Jan 29, 2013 | 01:01 PM
naf's Avatar
naf
Of course a body shop won't want to touch it. A used door should run you under $50, actually a hair under $45 in Louisville and under $40 in Canton. You don't want to pay what a shop would charge you when the used part is so cheap.
Don't know how far either is from you, but certainly would be worth a day trip to get that fixed. (Louisville pull a part has 4 firebirds).
Bet you could find something even closer.
Old Jan 29, 2013 | 02:07 PM
Car: 1984 Trans Am
yea there is 3 junkyards here maybe after winter leaves go and check again
1992 Trans Am
May 10, 2023 07:19 PM
diana227vegas
Jul 8, 2016 12:27 AM
86IROC112
Apr 9, 2016 10:20 PM
Out-Cast
Aug 23, 2015 06:33 AM
BlackTopKing
Aug 19, 2015 12:13 PM
