Dash
Old Jun 1, 2001 | 12:58 PM
PopaPork's Avatar
Dash
HELP...IT WONT STOP SQUEEKING!! I have taken it off to make sure it is nice and tight and it is. The thing squeeks right by the air vents in the middle...if I old it tight the noise goes away...any ideas??
89 Rs Camaro 305 TBI
Custom Performance Chip
Open Air Element
80 Series FlowMaster Muffler 2.5 inch Cat Back
BFG 235/60r15 Apperance: Black gray pinstripe. Black interior with Gray center piece in seat. Blue Gauge lights and 2 Blue neons under dash Board.
90 Iroc Checkerd Tail lights
Iroc Foglights
System: Pioneer 5200 Head unit Polk 3 ways up front and in the back. Kenwood 300 watt amp pumpin a 8inch JBL GT
"So many engines, so little time"
www.rit.edu/~cjp8408
Old Jun 1, 2001 | 01:11 PM
Scott_92RS's Avatar
Car: 1992 RS
Engine: 406 Stealth Ram
buy some advesive backed foam tape. Cut it into strips and put it between the stuff that squeaks together (air vents and dash pad?). It worked for me!
Old Jun 1, 2001 | 02:34 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Try loosening the screws. I have noticed that things can squeak when they have no movement available. If you keep the screws tight but not overly tight, the squeak may go away. I tightened the screws that hold the black frame under the Ttops once and had squeaks that became very annoying. If I grabb the Ttop frame, the squeaks went away. I eventually loosened the screws a little and the squeaks went away. The frame was still tight, just not over tight!
87 IROC 350 TPI with less than 10k original miles
93 Z28 Pace Car #494 of 645
86 Olds 442 (All Original)
My IROC Website
Northstar Camaro Club of Minnesota
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
86IROC112
Nov 7, 2015 06:50 AM
Fanatic1074
Oct 2, 2015 03:47 PM
lewandom
Oct 1, 2015 08:15 AM
Eric-86sc
Sep 28, 2015 11:37 AM
