Hood Springs????
Old Jun 5, 2001 | 08:50 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Hood Springs????
I just ordered my cowl hood and it should be here in a few days. Now my question is will the stock hood shocks be to much for the glass hood or will I need to get new ones or even springs. I checked the archives and couldn't find anything, even though I know I've seen this post before. Thanks in advance!!!
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Jun 5, 2001 | 10:32 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
There was a post before where a feww people with glass hoods used weaker hood shocks from junk yards. They were too weak to hold a steel hood, but strong enough for the glass.
Or you can do what my friend did on his Monte SS. He ditched the latch, hinges and shocks. Put four pins to hold the hood down. When he wants to work on his car he takes the pins out, and lifts the hood clear off the car. Talk about room to work!!
Old Jun 5, 2001 | 11:16 AM
cvpde37's Avatar
I eliminated my shocks completely. I use 3/8" stainless steel tubing. Crush the ends together, grind the rough edges off, polished, and drilled a 5/16" hole. They fit right on the stud where the shock used to mount. Looks great, works well and very low cost.
1984 Z28 350
Never argue with an idiot, they'll just bring you down to their level and beat you with experience
My Web Page
Old Jun 5, 2001 | 01:14 PM
gregz28's Avatar
cvpde, will you explain that one more time? Im trying to picture in my mind what your saying, but cant quite picture it. Id like to try it...
91 Z28 305 TPI
Plans for 383...
Jet-coated TES headers, Flowmaster cat-back,
SLP cam, Cloyes double roller timing chain, TPIS shocks/struts, TPIS STB, adj. fuel press. regulator, 170 stat, B&M shift kit, BMR 1.5" springs, Fastchip custom chip, gutted air box/ ram air from fog light intake, 1LE rear w/ 3.23 gears, 2" cowl hood, Hurst dual gate shifter, Mac Ewen white face overlays
150 MPH without law
enforcement on your
A$$? Welcome to Europe.
3rdgeners in Europe: Join us...
fbodyeurope.com
generation3rdgen
Old Jun 5, 2001 | 01:38 PM
cvpde37's Avatar
Greg, I'll try to post a picture on this thread a little later tonight. Meanwhile, I took a piece of 3/8" stainles tubing and put the ends in a vice with towels on the vice so I didn't mar them up. Crushed about 1 1/2" flat and the ground the corners down so it had a rounded finish. Then drilled a 5/16" hole in each end and they mount right on the stud where the old shocks fit. I love them for the car shows. If a wind kicks up it holds the glass hood in place very well. Like I said I'll try to get the pics up later.
1984 Z28 350
My Web Page
Old Jun 5, 2001 | 07:53 PM
cvpde37's Avatar
Here's the pic. It's not the best clarity, but should show you what I mean. I have two sets, one is 11.5 inches long and the other is 13.5 inches long. The longer ones hold the hood open to about the factory height. I use the shorter ones at the car shows.
Old Jun 8, 2001 | 10:37 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I got a pair of worn hood struts that someone was throwing away. They worked prefect for my glass hood.
90 RS Convertible
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Jun 8, 2001 | 11:34 AM
CraZ-28's Avatar
Car: 1991 Z-28
Now has anybody used the stock hood struts or are they too much for the glass hood? Mine look and feel like band new ones. Also, I remember somebody stating that there are hood struts disigned specifically for glass hoods. If this is true does any body have any idea where to get them? Thanks!
Old Jun 8, 2001 | 02:01 PM
Sharky's Avatar
Officially your not supposed to use stock hood dampeners(I think that's the proper term) with fiber glass hoods, but I've gotten away with it using a twin turbo hood. The dampeners were less than a year old when I put them on the hood too, so I was nervous, but they have worked pretty well even at full strength. I just try to be gentle whenever I open and close the hood.
If you do use dampeners with a fiber glass hood I'd recommend getting 2 hood pins in the front to help keep the light hood steady.
My hood tended to flap a little when going down the highway till I put some $20 chrome hood pins on last month.
You can see how my stock dampeners are attached on readers rides, click on the under-the-hood pic.
Drew Veeneman
87' Camaro
Jasper Class II 350 (.3 over)
Stock auto 700r4
Snail like 2.73 gears
K+N Air Filter
Road Demon 625cfm
Edlebrock Performer Intake
Edlebrock headers
3" Cat+Flowmaster
Ugly olive drab camoflauge paint job
Check Out Sharky at https://www.thirdgen.org/rides/index...ew&rideid=3002
[This message has been edited by Sharky (edited June 08, 2001).]
Old Jun 8, 2001 | 03:30 PM
CraZ-28's Avatar
Car: 1991 Z-28
Thanks to all for the info, I guess I'll just have to be carefull with the hood. I was just nervous about breaking a $400 hood in half. Also, I already have the hood pins, I figured that's what the hood would do so I got some before I bought the hood. Thanks again.
Hotrodboba400
Dec 10, 2019 07:07 PM
sandman92084
Sep 12, 2015 10:27 PM
lakeffect2
Sep 7, 2015 03:52 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
