Anyone know how to fix vertical slop in doors?
Old Jun 11, 2001 | 09:05 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
I replaced the hinge pin on my driver's side door but that didn't help at all. The door will move about an inch upward if you lift it, while the passenger side won't. Does anyone know a good fix for this? Do I need to tear the hinge assembly down further and use the bushings that came with the pin somewhere? Also, the local parts store doesn't rent out the tool needed to replace the hinge spring - any ideas on how to get that back in there? Thanks very much in advance.
"Life is pain! Anyone who says differently is selling something."
Old Jun 11, 2001 | 10:43 AM
KlayBuRn's Avatar
i had the same problem you did, here is what i did...still no play at all
https://www.thirdgen.org/messgboard/...ML/001456.html
Old Jun 11, 2001 | 08:53 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
So you basically replaced the hinge pin with a bolt right? What is the "special nut" that you used? I'm assuming you drilled that hole out to 1/2" since you used a 1/2 inch bolt...I just might give it a try.
Old Jun 12, 2001 | 09:00 AM
KlayBuRn's Avatar
like i said im no techno wizz, some kind of tool...
sorry man...
Old Jun 12, 2001 | 11:57 PM
burntblues's Avatar
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
its usually the door bushing is shot... try that
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
my86bird
Oct 23, 2015 12:20 PM
billybob6110
Sep 23, 2015 01:30 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
