Headlight Switch Knob removal???
Old Jun 20, 2001 | 12:54 PM
VortecZ's Avatar
Car: Camaros
Headlight Switch **** removal???
I have a 91 Camaro with two burnt out dash lights. I'm having trouble getting the dash apart becase I can't seem to remove the headlight switch ****. Is there a special tool or something?
Old Jun 20, 2001 | 03:28 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
If I remember correctly, there is a button on the bottom of the switch that will release the rod for the switch. If you look from under the dash you should be able to see it. If not you can feel it.
Hope that helps.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Jun 20, 2001 | 03:33 PM
David Petersen's Avatar
I know they changed the stlye a little bit but the switch may be the same as the older interiors. If so just remove the hex screws on the cover pull the switch all the way out and on the side of the metal switch housing there is a springed button, push this down and the switch **** will pull out then just use a very large flat head screwdriver to unscrew the black platic retaner nut.
Old Jun 20, 2001 | 06:02 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
In earlier models, the instrument cluster must be removed in order to access the 'button' that releases the ****.
JamesC
Old Jun 21, 2001 | 07:21 AM
purpleworm's Avatar
I had the same prob. I think the button is on the side. It is small and mushroomed shaped. When you push it in you can barely tell you pushed it. It doesn't move much. You will have to push it and wiggle the **** around till it wants to release. I could just take the bottom panel off the dash and stick my arm up to get to it.
Ghettobird52
Jul 5, 2024 11:18 PM
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
tnrednneck
Aug 13, 2015 08:57 AM
3rdgenparts
Aug 8, 2015 07:09 PM
