GETTING REALLY PI$$ED AT P. WINDOWS!!!!!!!!!!!!!
Old Jun 17, 2001 | 09:13 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
When I go to raise or lower the driver's side window (Passanger is fine) it stops after moving a few inches. sometimes in the same spots. I sprayed some WD40 in the tracks (I'm having trouble getting the whole panel off) this helped for a little while, I also switched the two 30 amp fuses and same thing. This happened twice last summer, once in the winter, and now happens ALMOST everytime I move the window. I wonder if I would have had all these problems with the 96 Stang my mom wanted me to buy (I thought that would help get replies)
late model 91 rs
fully loaded t-tops, red leather
paint- gm red and yellow blend (light red)
custom painted 16" Camaro rims
305 tbi 14"x3" O.E, computer chip, accel super stock plug wires
MTX sub and amp, Bose all around
vic_v8@yahoo.com
next week: Edelbrock 3" cat back; Next month: Iroc rear end
Old Jun 17, 2001 | 09:16 PM
dhirocz's Avatar
Car: '86 IROC-Z/'94 Z28
Engine: 350 LT1/382 LT1
Transmission: 4L60-E/T-56
Axle/Gears: 3.45/3.42 (soon 4.10)
Calm down!
Sounds like you need a power window motor. Common symptoms are slow windows, and those that stop after a few inches, especially when going up. Look into it. I'm 99 percent sure that's your problem. Unless you hear it binding, which is the other 1 percent chance.
And you would have problems with that 'Stang sooner or later.
Old Jun 17, 2001 | 09:34 PM
82 TRANS AM's Avatar
Car: 82 T/A WS7
Engine: Pontiac 400
Transmission: Muncie 4-speed
Other common problems are bad switches and occasionally the wires, where they go from the door to the cowl, can fatigue from opening and closing the door.
The car is 10 years old, how are you going to react when something major goes wrong?
Kenney
82 Trans Am WS7 notchback
83 Trans Am WS6 T-tops
Painter @ Chevy dealer
GM junkie
Old Jun 17, 2001 | 10:02 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
forgive me for acting up. I spent 5 hours making my car look great, another hour cussing at the window, sorry.
How do I check the wires?
How much is a new motor?
Old Jun 18, 2001 | 06:28 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
new motor will run you about $45 plus labor (another hour or so), if you have a shop doing it. Could probably save them a few minutes if you already have the door panel removed when you take it in...
KAM
Old Jun 18, 2001 | 07:21 AM
Blue92's Avatar
Yeah mine did the same thing. It was the window motor. I bought the part and then took it to the shop. $95 total p/l.
Pics of my Car
http://albums.photopoint.com/j/View?...781&p=39417549
http://albums.photopoint.com/j/View?...781&p=39417539
http://albums.photopoint.com/j/View?...781&p=29492902
http://albums.photopoint.com/j/View?...781&p=29492901
305TBI, EDL strut tower brace w/spohn SFC's on the way and wonderbar, ASCD big block hood,
Eibach Sportline Springs,
Koni Struts and Shocks,
SSPE lower control arms and Panhard bar,
Hellwig Rear Swaybar and Energy Suspension bushings.Aluminum Driveshaft. Posi-rear
Old Jun 18, 2001 | 11:49 AM
Polivick'sRS's Avatar
blue92,
where didd you buy your new motor at?
Old Jun 18, 2001 | 03:38 PM
Neo's Avatar
Neo
<font face="Verdana, Arial" size="2">Originally posted by Polivick'sRS:
blue92,
</font>
I am not Blue, but I got one yesterday from Checkers, it is a Delco too I am regretting doing this myself it is a bitch!
Mike Kenny
1991 Chevrolet Camaro RS 305 TBI
My Website
Administrator at Auto-Clubs.net
Moderator at ColoradoCamaroClub.com
My Baby
Old Jun 18, 2001 | 09:15 PM
how much guys?????????? and where at the dealer wantes like 180 here for one
Old Jun 19, 2001 | 01:09 AM
Neo's Avatar
Neo
I got mine for $56 with $10 back when I bring the old one back.
Old Jun 19, 2001 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Before purchasing a new motor, make sure that the window isn't binding, especially the two guides at the top of the door. As I recall, if the motor becomes too hot through binding, it will shut down briefly.
JamesC
Old Jun 22, 2001 | 01:49 AM
Teddy Z's Avatar
Before you go dishing a pile of money for a new motor you should try replacing the brushes. For $5 and a whole lot less effort you could be in business. Vader posted a how-to about this a couple weeks back... the motor stays in the door and you just remove the end to replace the brushes.
BTW the power windows in that rustang probably work fine but 5 hours of polishing wouldn't make it look good as a 3rdgen!!!
Here's the link to the link...
https://www.thirdgen.org/messgboard/...ML/009356.html
[This message has been edited by Teddy Z (edited June 22, 2001).]
Old Jun 22, 2001 | 11:43 AM
91z4me's Avatar
I also had the same problem on my 91 z. I went to a junk yard and watched them take the motors out of a 86 or 87 trans am. They were 35 a peice, but then this *** there said the regulator didn't come with them and he wanted another 35 for each one of them. So I said well just cut the ****ers off. They just knocked out the rivits and I am having them installed by a guy a Custom FX for 50 a peice. But hey beats 300 at the dealers.
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
kkirch15
Sep 30, 2015 04:44 PM
