Converting manual to power windows
Old Jun 10, 2001 | 11:54 PM
NCZ28's Avatar
I really want to put power windows into my camaro. I have everything from a camaro with power windows (guides, motor, etc.), but putting all of that stuff in my doors looks like it will be a real pain. Is there any way I could just mount the motors on to my existing manual windows?
Old Jun 11, 2001 | 12:47 AM
86NiteRider's Avatar
From: Somewhere around the South Side of Chicago just crusin' in one of the Niteriders
Car: 92RS 25th Anniv./88 IROC Z28 Vert
Engine: 305 TBI w/Tpi Air / 305 TPI
Transmission: 700r4/700r4
Axle/Gears: Posi
I NEED THE SAME INFO. THERE IS THIS ALARM SHOP THAT CONVERTS MANUAL TO POWER FOR $40.00 EACH DOOR. SOUNDS TO GOOD TO BE TRUE, HUH? THAT'S WHY I HAVE NOT DONE IT. WHAT ARE THE PROS AND CONS OF THIS?
[img]http//www.angelfire.com/sports/niterider/backmaro.jpg[/img]
86 Camaro Black SS Coupe, T Tops, Flowmaster, Custom Paint, Dunlop Road Kings S/R tires, Wheel Country Directional Chrome Wheels, New Leather seats, new carpet and headliner, complete front end suspension rebuild, new Valve seals, and more mods to come
http://www.angelfire.com/sports/niterider/86camaro.html
Old Jun 11, 2001 | 01:40 AM
birdofprey83's Avatar
Car: 1989 Firebird
Engine: 2.8
I have done this converson.
I suggest that you work with the interior stuff frist (i.e. the switches and the wiring harness) get all that stuff in your car. Then take the door inner pannels off. this part your going to need a second pair of hands- have some one hold the glass up and remove the track and the old crank arms. No, the moters can't just be mounted on the existing cranks. then insert the power assem. in to the door, I think that there was only one opening that it would fit through. insert the rollers in to the track on the glass and reinstall the guide track. then have the helper move the glass up and down until the rivet holes line up. (the rivet holes are already drilled in the door)
then I got a pair of the door side pockets to cover the hole where the cranks went through. they covered them nicely. study you donner car to see how it looks all done.
If you want to see the interior of my car go to http://www.geocities.com/birdofprey83/
Hope this helps and if you get stuck email me. (button on the top of this post )
Chuck
I'm not shy, I just
observing my prey.
My Firebird site
Old Jun 11, 2001 | 01:41 AM
pookey's Avatar
Not to sure how much it costs to convert but I am getting a used door with power windows/locks (to replace existing crappy sagging door) for $160.00 bucks installed. I think thats a pretty fair deal me.
88 White Formula 305 TBI With A New CD Stereo and Abolutly Nothing Else Done To It!
Old Jun 12, 2001 | 07:09 PM
Dumperbird's Avatar
Car: 87 Formula Firebird/ 84 Trans Am
Engine: 305 / 305 H.O.
Transmission: 700 argh 4 / same
If they only want $40 a door go for it. If the place does good work. Ask around. Really all they have to do is replace the maunal window gears and add some wires and swiches. I'm not sure on the cost of the motors but I'm sure there like at least $30 a pop. It's not too hard to do it yourself but if you can get it done real good and real cheap like you said I'd pay for it and I don't even like taking my car to someone else for an oil change!
You put Mt. Dew in the gas tank!?!
Wow, look at it go!
Old Jun 23, 2001 | 04:43 PM
mysterious83's Avatar
im going to put the power windows in from my doner car, any tips you can give on how to do a professional looking job
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
