Headliner in non T-Top car
Old Jun 23, 2001 | 11:03 PM
m3baller's Avatar
my car i just picked up has a sagging headliner.
what kind of stuff can i pick up for this? what is needed to do the job?
any links to how to redo the headliner?
Old Jun 23, 2001 | 11:10 PM
maksik7's Avatar
It si very easy to redo healiner in a Non T-Top car ( alittle harder with T-Tops). Should cost you under 40$ and it will look like new. Here are links to 2 detailed articles on how to do it:
http://www.iroc-z.org/tech/interior/headliner/
http://www.caraudioresources.net/bird_headliner.shtml
This works, I'm almost done with my T-Top headliner and its looking great. Will take you about 3-4 hours of work with setting time thrown in.
Hope this helps
-Max
Old Jun 23, 2001 | 11:29 PM
m3baller's Avatar
thanks for the quick response was planning on buying whatever was needed tomorrow
Old Jun 23, 2001 | 11:36 PM
m3baller's Avatar
do i need to do the fiberglass stuff even though i dont have t-tops
Old Jun 23, 2001 | 11:56 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If the headliner board is in good shape, you don't have to do the fiberglass. Just use a plastic brissle brush to scape off all the old crap, then spray the headliner and the new material with spray adhesive. After it starts to tack up, begin smoothing the material onto the board, starting in the middle and working your way out. Wrap around the edges, and cut out the necessary areas. The non t top headliners are cake. My t-top headliner looks like royal a$$ though. I've got to redo it.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Frozer!!!
Jan 19, 2024 04:55 PM
lee01
Apr 9, 2016 01:56 PM
Golfvette
Aug 24, 2015 06:35 PM
Linson
Aug 21, 2015 02:12 PM
3rdgenparts
Aug 6, 2015 09:03 AM
