my t tops leak pretty bad
Old Mar 11, 2013 | 05:28 PM
landon360's Avatar
Car: 1986 iroc-z
Engine: 350 tpi.
Transmission: 700r4 with shift kit
Axle/Gears: stock gearing
i was wondering how many people on here have replaced the seals on their t tops, mine leak in the corners where the t tops meet the car on the outer side. i was wondering if anyone else had leaks like this and if the seals helped i really dont want to spend $300 on seals and them still leak the exact same.
right above the back arrow is where mine leak on both sides and on the front in the same area on both sides
Old Mar 11, 2013 | 05:35 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: my t tops leak pretty bad
May just need sealer between weather strip and body.
Can use black RTV sealer. Use blue painters tape so it doesn't get all over everything .... if you got a garage, leave tops out for a day or two so it dries well.
If the seals are cracked and shot, then its time for new.
Old Mar 11, 2013 | 05:54 PM
82tarecaro's Avatar
I would install new weatherstrip. BTW - those are C&C t tops. Make sure you get the right weatherstrip if you replace it.
Old Mar 11, 2013 | 05:56 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
100% correct^^^^^^^^^
Old Mar 11, 2013 | 07:03 PM
landon360's Avatar
Car: 1986 iroc-z
Engine: 350 tpi.
that isnt my car just used it for reference, mines an 86 iroc z
InfinityShade
Aug 22, 2015 08:00 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
