Are all thirdgen camaro headliner boards the same?
Old Jun 25, 2001 | 08:01 PM
mcconahay37's Avatar
Are all thirdgen camaro headliner boards the same? I'm asking because I went to install a new headliner in my 82 and the headliner board was disintegrating on me as I pulled the foam off. A new board from classic industries is $120. I haven't checked with GM, but I'm pretty sure it'll be close to that. If all body styles are the same, I'll see if I can't find one in decent condition in a junkyard. Anyone else know of places I might be able to find one cheap?
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, TH350 tranny with 2500 stall.
SLP 1 3/4" headers
Old Jun 25, 2001 | 09:46 PM
Jza's Avatar
Jza
Yes, except for the obvious differences between the T-top and coupe, and overhead console vs. non-console.
Old Jun 26, 2001 | 08:16 PM
Thanks. That's what I figured, but I didn't want to make a mistake.
Old Jun 26, 2001 | 10:52 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Have you priced having it professionaly done? I just paid $120 to have one put in by a local seat cover shop.
87 Formula 305TPI T5
Old Jun 26, 2001 | 11:08 PM
KNTA4DNU's Avatar
Car: '97 Z28
Engine: 5.7
Transmission: M6
Can I take that statement back? Now that I re-read your post I realize they probably just recovered my old one.
Old Jun 30, 2001 | 05:41 PM
GarageToys's Avatar
Car: 89 Iroc Hardtop
Engine: LB9 w/G92 Pkg
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt, 3.45
You might be able to find one at a junkyard- most of them are junk, but today I found a mint black T-Top headliner and the yard only wanted $10. So I VERY CAREFULLY removed all the trim pieces that hold it in and gently popped the front 2 clips loose and Voila! I had a perfect headliner for $10. I sat it carefully on the hood of the car, went back inside the car & picked up my tools, and in the 20 seconds I was doing that, the wind blew it off the hood and it broke in half on the ground.
Moral- GM headliner boards suck. I'm going to buy an aftermarket fiberglass one.
1983 Firebird T-top- 383/TH350, South Side Machine SFC's & lift bars, 91 Formula bumpers, Harwood cowl hood, 89 T/A rear wing, 17" Centerlines, 89 Formula interior... Estimated completion date: never
Old Jun 30, 2001 | 06:16 PM
tinybfl's Avatar
At tacreationsusa.com you can get a fiberglass headliner for 100. I have no personal experience with it, but it seams a good deal. That and if i was going to replace the headliner I would go with the fiberglass anyway.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Mutillator
Exterior Parts for Sale
Jan 2, 2016 06:44 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
TheJoeY88
Aug 13, 2015 06:51 PM
