Painting engine bay ???
Old Mar 20, 2013 | 10:21 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so im painting my engine bay but im doing a por 15 coat im wondering do i have to use high heat por 15 or can i just use the regular por 15 to do it
Old Mar 20, 2013 | 11:35 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Painting engine bay ???
I paint mine with GM recondiction black but you will be ok with regular por 15
Old Mar 21, 2013 | 09:49 PM
Engine: LR4 4.8
Ok sounds good to know this is there a different rust eater spray besides the marine clean an metal ready im kinda running out an i need to prep it first before putting down the por 15
Old Mar 21, 2013 | 11:11 PM
Engine: LQ4 ls 6.0
Yeah we use SEM rust mort you just use a scraper and remove all the scale of rust do not sand or grind the rust then apply the rust mort wait 48 hours and the rust turns into black primer then you can apply and high build primer to fill in the rust Pitts if you have any
Old Mar 23, 2013 | 08:21 PM
Engine: LR4 4.8
Where do u get the sem mort at do they sell it at home depot, lowes etc etc
Old Mar 23, 2013 | 08:49 PM
Engine: LQ4 ls 6.0
No they don't have it you can look in you yellow pages and look for a aut paint supply store they will have some oreilly auto part stores or you can get it online. http://www.oreillyauto.com/site/c/de...2159&ppt=C0171
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
