Horn doesn't work on new Grant
Old Jul 10, 2001 | 09:21 AM
USA-1's Avatar
Car: 1987 Iroc Z "Classic Roc"
Engine: 5.7 350
I just installed my new Grant Carbon Fiber steering wheel. Looks great but I can't seem to get the horn to work. Any ideas? I know the horn works becaue the damn thing kept honking evertime the lead touched metal during installation.
Old Jul 10, 2001 | 10:37 AM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
<font face="Verdana, Arial" size="2"> I know the horn works becaue the damn thing kept honking evertime the lead touched metal during installation.</font>
Very simple there is a plate you were supose to put on under the horn button your just not make a solid electrical connection.
Rob
Chevy 2.8L, k&n filter lid, Headers Soon!!!
http://www.geocities.com/fiream/RobsCarArtPa.html?994187591828
Old Jul 10, 2001 | 10:58 AM
USA-1's Avatar
Engine: 5.7 350
That's what I thought but the plate didn't seem to fit. Also, if I remember correctly, the directions said that plate wasn't used with my steering wheel. Oh, brother. I gotta check again.
Old Jul 10, 2001 | 12:38 PM
fiream's Avatar
Engine: 400HP 350
Are you sure you got the right adapter kit? What wheel did you get, you should have to use the plate, you might have acidently put it one backwards, that what I did the first time.
Rob
Old Jul 10, 2001 | 12:52 PM
USA-1's Avatar
Engine: 5.7 350
Sure about the kit. Bought it at Pep Boys. The guy looked up the number right on the back of a Grant box and the car make and model. It's the Grant 1110 ultratech steering wheel. I have to check the directions again but I thought it said I don't need that contact ring. I don't think it will fit either.
Old Jul 10, 2001 | 03:57 PM
Diabolical's Avatar
Car: 85 Trans Am WS6
Engine: 305HO L69
how much did you pay for the wheel?
Old Jul 10, 2001 | 05:39 PM
mcconahay37's Avatar
First thing that came to mind is to check the fuse. You said it kept going off during installation, so you might have blown a fuse or possibly (hopefully not) blown the horn. If the fuse isn't blown, double check the install. The wire with the bell-shaped end goes through the spring and the plastic sleeve. This goes through the center of the steering wheel and connects to the horn button. The brown, funny-shaped horn adaptor piece isn't used since you have the 5 bolt steering wheel. It's only used for the three bolt steering wheels. Then, you put the horn button on and the cap over it.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, TH350 tranny with 2500 stall.
SLP 1 3/4" headers
Old Jul 11, 2001 | 03:16 AM
Omar's Avatar
Also, dont forget that new steering wheels will have a normally open and normally closed little pegs to hook your horn wire too. There's only 2, so if it's not working correctly, switch it to the other peg.
1989 IROC-Z 5.7L
NOS 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
redmaroz
Aug 16, 2015 11:40 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
