fround effects
Old Jul 11, 2001 | 06:17 PM
meridius's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
fround effects
does any one know if newer (91-92) rs style will fit on an 84 Z-28 because the nose looks a little different for example my parking lamps are recessed and the newer ones arent
I own a bad @$$ 84 Z-28
kills:
85-90 formula bird 2 times
some moron in a gran prix
2 different 5.0 stangs
and many other less impressive cars
losses;
not really a loss it was a not so stock mid 80s stang that turned down a side street
Old Jul 11, 2001 | 07:14 PM
Basett_Racing's Avatar
You will have to change the nose to put the 91-92 GFX on it. I have an 82 Z28, and I have a set of 91 GFX that I am going to put on it. You can use any nose off of a Z28 or IROC from 85 - 92. You can also use any 88-92 Camaro nose whether it is a SC, RS, IROC, or Z28. You will have to change the rear bumper, also, to use 91-92 quarter panel extentions.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads 72 cc Comb. Chambers, Comp custom grind Hyd roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 830 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET:11.60 @ 114.56, w/ a 7.34 1/8 @ 93.50, and a 1.622 60'
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
Bassett Racing
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
Damon
Sep 26, 2015 04:29 PM
James Sutton
Sep 23, 2015 01:56 PM
billybob6110
Sep 23, 2015 01:30 PM
ASE doc
Sep 22, 2015 03:13 PM
