Hood strut pivot pins
Old Apr 4, 2013 | 02:47 PM
Panther1's Avatar
Can these pins be removed and replaced? My hood blew up and trashed both hinges so I went to the jy and got two more hinges not realizing until I got home that the lower pivot pin for the struts were pretty much rusted away. being as they only swap parts and don't give refunds I guess I'm stuck with them.
Old Apr 4, 2013 | 03:49 PM
white gold 88's Avatar
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Re: Hood strut pivot pins
I have one rusted away on mine. I was thinking of doing the same thing. Was planning to just weld the new one to the hinge. Don't see why it wouldn't work, as long as the weld is strong.
Old Apr 4, 2013 | 04:02 PM
Panther1's Avatar
what will you use to replace the pin with?
Old Apr 4, 2013 | 04:26 PM
Car: 1988 Camaro
Engine: 385
Axle/Gears: 9 bolt
Pin from another hinge should work. Top and bottom are the same I believe. The bottom ones usually rust away from debris laying on top of them.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Fox118
Sep 12, 2015 09:29 PM
blackandblue02
Sep 10, 2015 08:19 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
