window problem
Old Jul 17, 2001 | 11:15 PM
sanet's Avatar
window problem
I have a gap between the driver side window and the rubber strip at the rear of the window that it should sit against which lets water blow in when it rains.I haven't been able to find a way to ajust it so far. I'm hoping that someone here can help me. The bushings are wearing but the door still closes easy and firmly. could this be the problem? I would be thankful for any advise I could get.
Old Jul 18, 2001 | 01:11 AM
CD MaroMan 91's Avatar
Maybe new weatherstripping? New window motor? Or maybe ur windows need to be adjusted to go up higher...
https://www.thirdgen.org/newdesign/tech/doorpanel.shtml go there and about halfway down the page it tells how to adjust your windows to go up a little higher
(orignally CDnAP48)
'91 Camaro RS (in readers rides)
Dark Metallic Blue
V6, 4th Gen Seats, Sony Xplod CD Player and Sony Xplod 6x9's, Kelly Charger Front Tires. Soon to come, DJSexay Kick Panels, Polk Audio Component Set, 2 Rockford Fosgate 12"
s, Rockford Fosgate Amp, New Rims, New Rear Tires, Carpet, Floor Mats, Paint Job, Interior Color Change.
E-mail me for any questions or comments.
AdidasPredator15@jam.rr.com
http://www.geocities.com/adidaspredator21/index.html
Old Jul 18, 2001 | 11:20 PM
orange rocket's Avatar
It doesn't need to go up higher if it isn't meeting the weather stripping. Try adjusting the two guides that are hidden by the top black molding. This will get rid of your loose glass and get it to seal properly.
Old Jul 19, 2001 | 01:51 AM
Blue_Meanie86SC's Avatar
yep, that's the problem alright, just have to make a few adjustments and it'll seal up just fine. took me about a half hour of tinkering to get it right.
Old Jul 19, 2001 | 12:06 PM
drtybrd's Avatar
Mine pass window does this now since I got it replaced about two weeks ago. Took it back to the glass shop that did it, and they say its the guide on the inside of the door that needs to be replaced, I have not gotten around to checking it yet. I can get mine to fit right if I shut the door, open the t-top and the close the t-top on it. Then it fits perfect.
1992 Trans Am
May 10, 2023 07:19 PM
evan555222
Sep 20, 2016 02:51 AM
pfsteichen
Feb 9, 2016 06:59 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
neekolzun
Aug 24, 2015 04:59 PM
