How to remove hood vents
Car: 1990 Trans Am
Axle/Gears: Stock
Hi,
how can those rear side vents from the '90 Trans Am hood be removed without breaking them?
I can see two screws on the two front vents, but there's no opening for the side ones.
Need to remove them all before getting the hood painted, but I can't find a guide :/
Car: To many to list
Re: How to remove hood vents
If you look through the openings in the hood , you will see two clips on each vent. You can get to them with a flat screwdriver.
Car: 1990 Trans Am
Axle/Gears: Stock
Ok, will take a look, thx.
There's still some foam in the openings so I didn't see anything last time.
