What's Wrong With My Tach????
Old Jul 19, 2001 | 08:33 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I just installed an Autogage 5" tach with shift lite. I set the shift point to 4200 rpm's the other day, and today when I was shifting the light didn't go off. I found out the reason when I turned the car off and turned the igition on, somehow the shift point moved up to 6000rmp. So I reset it and tried again and the shift point changed to 4000rpm. Why is the shift point changing, supposedly it can only change with the ignition on and turning the ****?
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
2:73 GEARS
Rebuilt 700R4, with manual valve body
B&M Megashifter
Soon to be installed
3:73 Richmond Gears and 3" Hooker Aero Chamber
Corvette Servo & .500 boost valve
15.61@ 95.2mph G-Teched, 1-2 shift slippage
"There is nothing more addicting than speed"
Old Jul 20, 2001 | 07:33 AM
purpleworm's Avatar
It shouldn't be able to change. Mine stays in the same place all the time. Does the the tach work alright other than that? Where did you decide to put it?
Old Jul 20, 2001 | 09:17 AM
zupmanZ28's Avatar
Car: 86' Z28
Engine: 355
It's probably defective. I'd send it back, they'll replace it for ya. If im not mistaken i have the same exact tach as you wand mine doesn't move unless the ignition is on and the isn't running. Where did you buy it from?
My 1986 Z28
GM350, T-5, 3.23's, lots of go fast goodies, 4th gen Firebird interior etc...
85 IROC w/ 1364 miles!
You'll always find what you've lost in the last place you look
R.I.P Dale Earnhardt
Old Jul 20, 2001 | 03:34 PM
Car: 99 Formula
Axle/Gears: 342
I mounted it on the A pillar. The tach works great besides this one thing, I would hate to have to undo it and replace. My dad got it from Autozone.
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
2:73 GEARS
B&M Megashifter
$750 L98
Feb 1, 2025 02:25 PM
Fanatic1074
Oct 3, 2022 05:57 AM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
sheachopper
Jul 31, 2019 11:27 AM
Eric-86sc
Sep 28, 2015 11:37 AM
