'Z' Rated?
Old Jul 19, 2001 | 06:42 PM
KlayBuRn's Avatar
'Z' Rated?
i have learned that there is the speed limiter on my 92 RS of 108 MPH because my tires are not 'Z' Rated, i have a set of Eagle GA's, they cost me like $150 around there a piece, how do i tell if like after this weekend when i reprogram the chip to bypass that if my tires are gonna blow up when im doing like 125mph?
any ideas or thoughts?
Old Jul 19, 2001 | 07:02 PM
Jiffy's Avatar
Im not sure if this is this is the answer to the right question, but if you want to know if your tires are Z rated, they will say on the side before the first set of numbers.
Old Jul 19, 2001 | 07:05 PM
KlayBuRn's Avatar
what does it mean to be Z rated?
Old Jul 19, 2001 | 08:58 PM
Gen X Mar0's Avatar
Car: 1991 Z28
Engine: 5.7 Stealth Ram
Transmission: Pro-Built 700R4
here are all the definitions of the speed ratings
Q-speed rated Capable of speeds up to 100 mph.*
S-speed rated Capable of speeds up to 112 mph.*
T-speed rated Capable of speeds up to 118 mph.*
U-speed rated Capable of speeds up to 124 mph.*
H-speed rated Capable of speeds up to 130 mph.*
V-speed rated Capable of speeds up to 149 mph.*
W-speed rated Capable of speeds up to 168 mph.*
Y-speed rated Capable of speeds up to 186 mph.*
Z-speed rated Capable of speeds above 149 mph.*
Old Jul 19, 2001 | 10:33 PM
One Eyed Jack's Avatar
I want Y rated tires then, right?
Old Jul 19, 2001 | 11:34 PM
Jza's Avatar
Jza
Z is the best. Note it says "above" instead of "up to".
Old Jul 20, 2001 | 03:44 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The following statement came right off the Tirerack.com website. I would disagree that Z rated tires are the best!
"When Z-speed rated tires were first introduced, they were thought to reflect the highest speed rating that would ever be required. Since that time the automotive industry has found it necessary to add W- and Y-speed ratings (indicated in the tire’s service description) to identify the tires that meet the needs of new vehicles that have extremely high, top speed capabilities.
Miles/Hour Kilometers/Hour
P225/50ZR16 149+ 240+
P225/50ZR16 91W 168 270
P225/50ZR16 91Y 186 300
While all Z-speed rated tires are capable of speeds of 149 mph and above, prior to the W- and Y-speed ratings were identified in the service, how far above 149 mph was not identified."
Z-rated typically is for 149+ but how long will the tire last at sustained speeds of 149+ was not known. Thus the entrance of the "Y" and "W". They are rated at higher speeds and can sustain long distances up to 186mph (Y) and 169mph (W).
87 IROC 350 TPI with less than 10k original miles
93 Z28 Pace Car #494 of 645
86 Olds 442 (All Original)
My IROC Website
Northstar Camaro Club of Minnesota
PurelyPMD
May 5, 2016 04:57 PM
3rdgenkindagal
Aftermarket Vendor Review
25
Oct 21, 2015 09:32 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
