privacy cover install
Old Jul 4, 2001 | 12:18 PM
jayman350's Avatar
Hey everyone,
I just bought a cover for the rear hatch and it didn't come with mounting screws. My question is what can I use to put it on? Also where does the cover attatch to? I don't see anywhere for it to latch on.... any help is appreciated on this
Jay
[This message has been edited by jayman350 (edited July 04, 2001).]
Old Jul 4, 2001 | 01:15 PM
89RustangRemover's Avatar
Hey Jayman,
The cover itself is held by a connector that go by where the sail panels are...on the plastic part...one on each side...those are screwed on there...and it latches on the hatch itself...where the glass meets the plastic part on the inside...it should have a couple of notches on the hatch...but...if it was not originally equipped with one...then it's not gonna have the notches on the hatch or the connectors on the sail panels...I don't know if you have to get a new hatch w/notches or what...my guess is that your car was not originally equipped with that option...good luck man....
Me...
"WARNING: Objects in mirror are about to disappear VERY quickly!"
Old Jul 5, 2001 | 03:01 AM
86ZRICHIE's Avatar
if that's the one you're talkin about, then the pattern for the holes in the sail panels are indented onto the back of the panels. take them out and use a dremmel to cut away the holes.
Now, if you're talkin about the hinged cargo cover, you'll have to get the mounting brackets off a donor car and weld them onto your car (I just used JB weld, worked fine)
Old Jul 24, 2001 | 09:19 PM
jayman350's Avatar
Its the spring loaded cover and I got the mounting brackets off of ebay (where else) I have heard something about metal plates located behind the plastic interior pieces, do I absolutely need these? If I do I am guessing I can fab something up and be set with it. Now where should I be looking for these things? around the sail panels?
Old Jul 24, 2001 | 11:25 PM
Blue_Meanie86SC's Avatar
you don't need the metal pieces, the cover will hold itself in nicely. As for the holes for the mounting plates, take off the sail panels and on the back side you'll see an indentation where the spots for those should've been cut out. cut them out with a dremel and you'll be good to go
Old Jul 25, 2001 | 12:18 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I cut the metal reinforcements off a wrecked car and pop riveted them to my IROC. I suggest you do the same.
90 RS Convertible
Owner: Top-Down Solutions
http://www.sc3gfb.org/members/lonsal.html
http://www.taskerinc.com/gs3/profiles/Lon_profile.htm
Old Jul 25, 2001 | 08:47 AM
jayman350's Avatar
cool, thanks everyone I have been getting kinda nervour about leaving my car with the sub showing so I have been just putting the t-top bag on top of them but it doesn't completely cover the amp. I will probably do some work with it tonight.
Jay
350 is finally in!!!
black 85 Z28, t-tops, 350 4-bolt main w/ Edelbrock Performer RPM intake, Holley 600cfm carb, Edelbrock shorty headers, bunch of chrome, and some other stuff that isn't worth mentioning here, flowmaster 80 series muffler w/ custom tips (hollowed out cat), MacEwan white face gauges, Infinity 4" 2 way plate speakers, Infinity 3-way 6x9s, 12" JL Audio W3-D4 (custom box so my t's still fit back there), Alpine V12 MRV-T501 amp, Alpine CDA-7863 head unitJay's Website
No car with 4 doors is a sports car! this goes back to my friend comparing his Maxima to a Camaro
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
I'llrocya
Feb 2, 2016 11:43 PM
